eastbaysolo_73
Post by eastbaysolo_73 » 10 Dec 2018 12:46
greenthumb wrote:
09 Dec 2018 21:36
Looks fantastic! Those dapper lights have the halo or angel eyes effect?
Thanks Greenthumb they do have have the halo rings.
eastbaysolo_73
Post by eastbaysolo_73 » 17 Dec 2018 14:16
finally got the car off the jack stands this weekend. It still needs to have some suspension adjustments. But good enough for now.
Imagenomorejacks by v p, on Flickr
jefe de jefes
Post by jefe de jefes » 18 Dec 2018 21:30
eastbaysolo_73 wrote:
09 Dec 2018 19:48
Mounted the rear cross member today and rear coils. Need the car on the ground to make room for my wife's car.
Put on the rear wheels as well. I need to set the ride hight once I get the front suspension buttoned up and wheels installed.
ImageRearcoil by v p, on Flickr
Imagerearwheel by v p, on Flickr
Where’d you get the qa1’s?
drawks
Post by drawks » 19 Dec 2018 07:31
17 Dec 2018 14:16
Those mesh wheels look dope! I had some enkei 92 meshies on my first dime back in '95
eastbaysolo_73
Post by eastbaysolo_73 » 19 Dec 2018 11:27
jefe de jefes wrote:
18 Dec 2018 21:30
09 Dec 2018 19:48
Got them from here at DPracing.
http://www.dpracing.co
eastbaysolo_73
Post by eastbaysolo_73 » 19 Dec 2018 11:32
drawks wrote:
19 Dec 2018 07:31
17 Dec 2018 14:16
Nice! These wheels are 3 piece AME wheels, which are actually made by Enkei. They were only offered in Japan as there luxury brand.
jefe de jefes
Post by jefe de jefes » 19 Dec 2018 13:32
19 Dec 2018 11:27
18 Dec 2018 21:30
09 Dec 2018 19:48
Thanks man
KiKiIchiBan
Post by KiKiIchiBan » 08 Jan 2019 13:05
Not today, but I have finally primed my engine.
https://www.youtube.com/watch?v=wRZHzYc9NhI
I did try to start it, but it didn't fire up, I think there is something wrong with the coil, or with my knowledge, couldn't get a spark either way.
My Bluebird SSS Coupe #25
Post by bertvorgon » 08 Jan 2019 17:41
Unlike our poor compatriot above me, my car started on the 2nd crank, which surprised the hell out of me, it was 39F (4C) in the garage. My new storage garage, not that I'm complaining, has the attic hatch right above my car. So, when my daughter or son-in-law need to remove anything, or, in this case put the Christmas decorations away, I need to move the car. At that point I then need to let it run and bring it up to 200F. to eliminate any water/condensation.
As I have no choke I just let the float bowl fill up, give the throttle a 1/2 dozen good blips, to get the accelerator pump dumping a good slug of fuel in there, let it sit for 30 seconds to try to evaporate in the cold, then hit the starter. Wham, it virtually lit off with two cranks. I cycle all the relays, fan to high, wipers, lights, just to keep things moving. After 15 minutes slide the car back into it's slot and now can be good till spring.
I did remove the glove box, for a small project which I will start a thread on in case anyone is interested
Tedman
Post by Tedman » 13 Jan 2019 00:27
Installing a remote oil filter mount. Last week I got the filter mounted on the strut tower with the Traco mount. Today I installed the BRE remote filter block adapter and assembled the oil return hose.
Post by two_68_510s » 15 Jan 2019 13:28
AN 6?
Tedman
Post by Tedman » 20 Jan 2019 21:54
two_68_510s wrote:
15 Jan 2019 13:28
AN 6?
AN -10
KiKiIchiBan
Post by KiKiIchiBan » 10 Feb 2019 08:50
I started mine up for the first time :)
cartel
Post by cartel » 06 Mar 2019 07:04
Bolted on new wheels... New vto installed. Over inch clearance to wheelwell on rear and about 3/16 to control arm.. I think with a modified arm 225s will fit..
Mike Gibson
iceman510
Post by iceman510 » 07 Mar 2019 11:20
More details please.
Wheel size and offset?
Tire size?
