Post by defdes » 13 May 2019 08:39
I bought a new O2 sensor (narrow band) spliced on the connector for the AutoMeter gauge and welded on a bung. I'll invest in the wide band eventually when I finally switch to EFI.
cartel
Post by cartel » 23 May 2019 18:04
got my center caps done to be different--
in dropbox the image is horizontal but after creating the link its showing rotated..
Mike Gibson
eastbaysolo_73
Post by eastbaysolo_73 » 24 May 2019 10:52
Finally done with most of the rack install on the inside of the engine bay. finished installing all the brake lines as well. Came out pretty good.
ImageRackdone by v p, on Flickr
Post by bertvorgon » 09 Jun 2019 17:21
As I postponed our drive till next Sunday I thought I would be productive on the car today.
Drove over to Specialty where I proceeded to replace a torn shifter boot, been like that for too many years. I had two new ones in stock, one made in Mexico and one factory. It also let me check out and re-lube my steel shifter bushings which Andy made for a precision fit. No wear at all.
I have a small foam "cone" that goes around the top of the trans mission at the shifter area, keeps things a bit quieter, it was still in good shape
I then fixed a couple of small vibration/rattle issues in the engine bay, my heat shield separated from it's silicone isolator and a hose clamp was hitting my brake switch heat shield.
Andy popped a rear wheel off my car so he could measure up some brake pads for another customer who uses the same set up as mine.
It was a nice drive back to sunny Surrey where I fueled up the car with fresh 100LL, ready for next weekend.
IMGP4800 (Large).jpeg (352.24 KiB) Viewed 575 times
IMGP4799 (Large).jpeg (287.22 KiB) Viewed 575 times
IMGP4798 (Large).jpeg (402.26 KiB) Viewed 575 times
Precision machined for my shift rod, steel bushings.
IMGP4797 (Large).jpeg (292.86 KiB) Viewed 575 times
eastbaysolo_73
Post by eastbaysolo_73 » 17 Jun 2019 18:00
Started adding some sound sound deadening to the car.
Imagesoundd by v p, on Flickr
Tedman
Post by Tedman » 28 Jun 2019 20:49
Installed drip rail trim! Gotta admit, gave myself 50/50 chance of succeeding with this. Never installed (or removed) drip rail trim before. Required a lot of careful whacking with a soft rubber mallet, but it went on! Stoked!
Post by RONSLYCHUK » 29 Jun 2019 10:59
You did a good job,congrats!
510-Trevor
Post by 510-Trevor » 29 Jun 2019 18:54
This past week I mocked up some metal flares and replaced the front wheel bearings and brakes. Still have the right side to complete but with what I learned on the left side the right will go much faster.
1-front and rear flare mockup with wheels.jpg (78.88 KiB) Viewed 273 times
1-front and rear flare mockup.jpg (88.15 KiB) Viewed 274 times
front brakes.JPG (75.57 KiB) Viewed 284 times
1972 Yellow 4dr
eastbaysolo_73
Post by eastbaysolo_73 » 12 Jul 2019 18:01
510-Trevor wrote:
29 Jun 2019 18:54
Looks killer man.
Post by bertvorgon » 14 Jul 2019 19:39
Birdy is not coming home......
I decided to go and fire the car up, drive to Andy's to wax and check a few things out after our Fort Casey drive. I did wash the car after the drive..but.....
Today as I waxed the car, where I actually got down low on my knees, to wax the air dam, I saw something jammed into my oil cooler inlet. This is what I found! I did remember on one of our zippy points going back up the old #99 and a bird flew across the front of the car, I did not think I saw it exit..but...it was low and maybe I just did not see it. At the gas station I checked the grill and saw nothing. I obviously should have looked lower. Talk about threading the needle to hit that opening at 70 MPH.
Took me a bit to drag this poor thing out, was it ever jammed up there, I don't think it was the impact that killed, it but the sudden right turn.....
I took a quick run after waxing the car to Vancouver to visit Rob France, then blasted back down #99 to the garage. I had an interesting discussion with some sort of Larger JDM Toyota that had some good power, turbo I think, but, I scored final point during the discussion. At some point during that final part of the discussion I saw close to 8,000 RPM in 5th..zippidy do dah....
I will throw some more fuel in it for next weekends drive and clean some bugs off the windows.
IMGP5079 (Large).jpeg (230.1 KiB) Viewed 49 times
IMGP5078 (Large).jpeg (234.21 KiB) Viewed 49 times
IMGP5077 (Large).jpeg (333.62 KiB) Viewed 49 times
IMGP5076 (Large).jpeg (336.75 KiB) Viewed 49 times
CP
Post by CP » 14 Jul 2019 20:26
Just shy of a year since we dropped a valve seat, we finally have things back together and running. Learned a lot on this go around, like stick with a known machinist. Would have saved a lot of headache. Little more set up and clean-up and she is out the door for the balance of the summer.
20190714_200146 (Large).jpg (345.91 KiB) Viewed 42 times
