Interesting ebay Finds
Hakosuka510
Re: Interesting ebay Finds
Post by Hakosuka510 » 25 Mar 2020 17:43
Dumb question: how close does the 2-piece hinged, steel pedal from the Nissan forklift come to being a bolt-in, Nissan replacement for the original 510 plastic living hinge accelerator pedal for those of you wanting to keep it? Found this on eBay just now and instantly recognized the pattern:
https://www.ebay.com/itm/NEW-NISSAN-181 ... 3386622967
May make a separate thread just for this since it's relevant outside of eBay. I never use the original pedal anymore (I always either mount an OMP pedal to the original arm or just convert to the entire assembly out of later models), but I thought some of you may be interested.
s-l1600 (1).jpg (186.4 KiB) Viewed 119 times
Post by RMS » 25 Mar 2020 18:19
6inches could use that ....buy no....40 for shipping :shock: ...piano hinge its is.
unless...
part # 18110-L1100
bastards kept with the number ..... https://www.amazon.com.au/Blesiya-Nissa ... B07PNVQ9GZ
Hakosuka510
Post by Hakosuka510 » 25 Mar 2020 23:54
Eewww, I can smell the nasty mainland Asia knockoffness from here. Plus it just doesn't look period correct, which for someone set on retaining the floor-mounted hinged pedal, is probably a consideration.
To be clear, the one I linked to on eBay is genuine Nissan, just repacked in a third party bag. There's an almost identical assembly in the Nissan bag also on eBay for $7 more, but it has a different hole spacing.
