Progress of your CV axles please?
Mattndew76
Post by Mattndew76 » 13 Oct 2008 20:34
Can you guys post some updates on your CV kits please?
Matthew
(I miss my dime)
slodat
Re: Progress of your CV axles please?
Post by slodat » 13 Oct 2008 20:57
I bought the axle shafts and dropped them off at Dutchman Friday. I will be ordering adapters from you on payday!
'70 510 2 door
chopped '69 521
Post by okayfine » 14 Oct 2008 08:14
Mine are on a project car which isn't yet running, so there's not much I can share.
DQ article should be imminent.
The test fit:
seemed to indicate that the sweet spot for the axles is the 14.5" that was originally suggested.
Mattndew76
Post by Mattndew76 » 14 Oct 2008 10:05
If I can get 6 or more people buying I can do another $200.00 per kit group buy sale. No hardware this time though. That box I had was expensive :shock:
Post by okayfine » 14 Oct 2008 11:08
Mattndew76 wrote:If I can get 6 or more people buying I can do another $200.00 per kit group buy sale. No hardware this time though. That box I had was expensive :shock:
I hadn't even planned on CVs for Whitebird, however Matt's insane price of $200 for the adapters was too insane to pass up.
Mattndew76
Post by Mattndew76 » 14 Oct 2008 12:28
It saves money for everyone to do these in bulk buys. It helps me on the cost of material.
Pedro
Post by Pedro » 14 Oct 2008 17:29
Hey guys, what cv's and axles are you using for this conversion? is there another thread showing which ones are used?
Post by defdes » 14 Oct 2008 17:54
"SEARCH" and ye shall find....
Pedro
Post by Pedro » 14 Oct 2008 18:15
Yep should have done that, my bad.
freekwonder
Post by freekwonder » 15 Oct 2008 02:13
I know I should probably search first, but what are the details on your kit? What does it work with, and what else would I need to make it work?
thisismatt
Post by thisismatt » 15 Oct 2008 08:24
It works with searching, and you will need to search to make it work. :roll:
I'm your huckleberry.
Mattndew76
Post by Mattndew76 » 15 Oct 2008 10:26
Should we make a sticky of the list of parts so people can be lazy about the search option?
iceD
Post by iceD » 15 Oct 2008 10:33
If it helps put a deal together for a few of these kits then yes.
ice D
alfa7kar
Post by alfa7kar » 15 Oct 2008 12:21
I purchased a set from matt. i currently have the whole set up installed and have put about 200 miles on them. i purchased the 15 5/8 sand rail axles from ebay and the cheap cv joints also from ebay. the axles are case hardened. i had a local machinist mill the ends off and cut the retaining clip slot on a lathe. he said that they are real hard. i have only had one problem i think my car was a little to low and i dont have a adjustable rear cross member. i think the angle was a bit to much and it pulled the inner part of the joint out a bit causing the axles to slip out of the splined area. i took the inner joint apart and repositioned the joint then raised the car a bit in the rear. this seems to have solved the problem.
carlos :mrgreen:
Mattndew76
Post by Mattndew76 » 15 Oct 2008 12:24
Thanks for the update Carlos. Get some pics up if you can.
