What kind of Gas does ur Dime like??
sdterrible1
Post by sdterrible1 » 09 Mar 2009 13:51
Lets see what some of us are filling are cars with, do you prefer one brand over another?
List your motor and mods and what runs you 510 the best!
Drive a Datsun
Re: What kind of Gas does ur Dime like??
Post by bertvorgon » 09 Mar 2009 18:19
I run Chevron 100LL Aviation fuel for street and mild boost 14psi
For our road trips, I run Chevron 94 Octane, doctored with a deadly mix of chemical to boost the octane to 100
I run C-16 for sustained boost applications, under race conditions, 16PSI.
I also spray some methanol into the inlet of the turbo.
10:1 compression and boost.
Avgas is made to very high standards, so it does not make a difference if it is Shell or Chevron. Most of our gas stops are at Chevron, so that is what we tend to fill up on with the 94.
C-16 seems to work very well in our turbo applications..
I run Mowhawk Regular 90 in my Toyota GTS, as I get the added octane for the same price as 87 regular, and it seems to work just fine.
bbejj123
Post by bbejj123 » 21 Mar 2009 12:22
Shell 91 Octane Stock L16 :D
Post by defdes » 21 Mar 2009 17:34
Chevron 91 FJ20 (2.1) 10.5:1. I would run 94 if we had it.
Benzo
Post by Benzo » 21 Mar 2009 20:07
91 octane shell,chevron or 76. pretty much any 91 octane runs ok. if my compression was lower I would usa 89 or 87. buy since comp ratio is high I would not even mind using 93 octane if available
510Freak
Post by 510Freak » 21 Mar 2009 22:05
sdterrible1 wrote:Lets see what some of us are filling are cars with, do you prefer one brand over another?
My motor ,Umm a middle aged structure.
Is a numbers matching unit,Hope to keep er that way,
She really wants to go but the rear gears seem to lag a bit tho..
Runs the best on, good old home made fuel..
Oh poo I thought we was talking about owners :lol:
Anything over 89 is better in a 510
