i think my engine is dead......
Good read, and they do specify that you would have a max of 5% decrease in performance when running regular in a premium-recommended engine.
That little 5% can be noticed by some peeps. I noticed a dif. on that L16, it has more get up and go when running premium. Exhaust smells different..
OH! Here's something...
Should you run leaded or unleaded gasoline in a datto(L16) ? It has the old leaded gas filler cap, instead of the new unleaded-only cap.
Steve Boatman
Grants Pass, OR
1971 510 2DR | KA24DE
Grants Pass, OR
- ///FiveOneOh
octain = compression ratio. if your car needs 91 and u put 87 in it. of cuz u'd lost peformance but if the engine was design to run 87. putting race fuel wont increce power.
the pev owner of my car put only 94 and turned the carbs to very rich. not only it's pointless, that also sucks gas. more is not always better. since i dont know the compression ration of my car. im gonna run lower and lower octian , to the point it start pinging. than put a little better gas than what i need
Timing is at 0 even, if I remember right.
It pressure-gauged OK, but thats not to say the gauge was broken. It's got water inside, so it could be off a bit.
Will have to slap a light on it and make sure it's on, but I'm pretty sure it's where it needs to be.
Steve Boatman
Grants Pass, OR
Grants Pass, OR
But in that case you may notice a decrease in power...Cazzzidy wrote:"Timing is at 0 even, if I remember right."
Retard your timing to 6 degrees and you wont need to run premium.... 87 should be fine.
EDIT: Oh woops, I thought you said retard it 6 degrees, not TO 6 degrees.
