Post by defdes » 13 May 2019 08:39
I bought a new O2 sensor (narrow band) spliced on the connector for the AutoMeter gauge and welded on a bung. I'll invest in the wide band eventually when I finally switch to EFI.
cartel
Post by cartel » 23 May 2019 18:04
got my center caps done to be different--
in dropbox the image is horizontal but after creating the link its showing rotated..
Mike Gibson
eastbaysolo_73
Post by eastbaysolo_73 » 24 May 2019 10:52
Finally done with most of the rack install on the inside of the engine bay. finished installing all the brake lines as well. Came out pretty good.
ImageRackdone by v p, on Flickr
Post by bertvorgon » 09 Jun 2019 17:21
As I postponed our drive till next Sunday I thought I would be productive on the car today.
Drove over to Specialty where I proceeded to replace a torn shifter boot, been like that for too many years. I had two new ones in stock, one made in Mexico and one factory. It also let me check out and re-lube my steel shifter bushings which Andy made for a precision fit. No wear at all.
I have a small foam "cone" that goes around the top of the trans mission at the shifter area, keeps things a bit quieter, it was still in good shape
I then fixed a couple of small vibration/rattle issues in the engine bay, my heat shield separated from it's silicone isolator and a hose clamp was hitting my brake switch heat shield.
Andy popped a rear wheel off my car so he could measure up some brake pads for another customer who uses the same set up as mine.
It was a nice drive back to sunny Surrey where I fueled up the car with fresh 100LL, ready for next weekend.
IMGP4800 (Large).jpeg (352.24 KiB) Viewed 224 times
IMGP4799 (Large).jpeg (287.22 KiB) Viewed 224 times
IMGP4798 (Large).jpeg (402.26 KiB) Viewed 224 times
Precision machined for my shift rod, steel bushings.
IMGP4797 (Large).jpeg (292.86 KiB) Viewed 224 times
eastbaysolo_73
Post by eastbaysolo_73 » 17 Jun 2019 18:00
Started adding some sound sound deadening to the car.
Imagesoundd by v p, on Flickr
