jason
Post by jason » 27 Sep 2009 19:30
I drove my 'goon today :twisted: !
iceD
Post by iceD » 27 Sep 2009 19:38
I drove my tudor to Jason's house, and bought a part from Byron.
ice D 8)
jason
Post by jason » 27 Sep 2009 19:50
Sorry to miss you Derek, I was at work :( !
iceD
Post by iceD » 27 Sep 2009 20:09
That's OK. I like your collection.
ice D 8)
jesusno2
Post by jesusno2 » 27 Sep 2009 20:13
I finished up por 15 ing my floor boards today. Got my h4 headlights installed and started prepping the inside for paint that matches the rest of the car! That was all I got done this weekend.
jason
Post by jason » 27 Sep 2009 20:14
Thanks Derek, need to get to work soon I think! Winter's coming ....
McShagger510
Post by McShagger510 » 27 Sep 2009 22:29
Changed the diff in the Green Machine - trying to sort out loud drivetrain racket.
'91 Nissan truck *SOLD*
'02 TOYOTA Tacoma
Post by Byron510 » 27 Sep 2009 22:48
I played the Wreckin Man today. I hate brining 510's to the end of their life, but this one is proving to be a real donor car - which is a good thing. So far, not including tonight’s post, it's parts are already going into 7 different peoples cars. It'll likely be over 12 to 15 cars by the time the dust settles; a GOOD thing. The motor will be in my brother car in a few weeks, trans going to Tycot, IceD got one tiny trim piece, Jason will no doubt get quite a bit of trim stuff, Ash510 got the wiper linkage, dp61 – the trunk lid is in really goor shape, and I even removed the hinges for you! Give mne a call; the rear package tray shelf will likely find a temporary home in the back window of Ole Blue… I know I missed something here – and then there are tonights requests!
Got the motor pulled, interior out (except the head liner - Peter was working on that for me and gave it a good head start though (Thanks Pete and it was good to see you drop by!), Dash got safely removed, doors and all trim off. Removed the rad support (I love my Makita saws all!), gas tank out - the shell is looking pretty bare, I wished I'd taken a photo today, but I will next time I'm out at the car. Next time I’m out there I’ll have all the suspension and the rest of the wiring harness out.
Best part of the day was how it ended. A guy dropped in driving a 60's Renault Gordini, names Paul. Supper nice guy. He just saw me working on a 510 and just stopped to chew the fat. I wished I wasn't already late for getting home (my wife must be so used to this by now, but it's still not right). Turns out this guy is a real Webber guru, and as I was talking to him I realized that McShagger had told me about this guy years ago. I hope I cross paths with him again as I never got any contact info other than his name was Paul! Next time I hope I'm in one of my own 510's but it was a cool chat just the same.
jason
Post by jason » 27 Sep 2009 22:52
Geeze, I missed Paul too :( ! I have Paul's contact information if you need Byron, he's a super nice guy and has some amazingly nice stuff in his shop in Vancouver!
Post by goichi1 » 27 Sep 2009 23:25
I drove the bluebird to work today, seems to be ok with the fuse problem....I will drive up to UpGarage when I get off work, I saw a set of helper springs that might fit the rear, trying to fix that rattling spring back there....I hope they are the right size....they were only 30.00 for the pair. I will also see if I can get a set of front springs that are a little softer...want to try something out....there were bunch there...just not sure of the rate and size.
Post by icehouse » 27 Sep 2009 23:37
Byron I think the 510 guys stole the idea of this thread from the truck guys over there. I think for me it will be "What did you do on A 510 today?" since a lot of the cars I work on aren't mine :D
Today I stopped buy a work buddies house (not Carter) to help him get his wagon running. He was selling to another guy at work (not Carter) and they wanted my help. When I got there I had him pick up some new plugs, while I checked wiring to the coil, firing order, compression and cleaned the cap and rotor with my trusty pocket knife. The number 4 cylinder was a little low on compression but I figured it was because they started working on it at 9 and I didn't show up until noon so the cylinders have had there share of fuel :D Messing with the dizzy timing the new plugs and bypassing the ballast resistor made all the difference. The L20 fired up nicely. Then I was off to fix some of the other problems, the car won't shut off with key problem, fixing the wiring so you don't have to touch 2 wires together to get the car to crank and a few other minor details.
I kinda miss grinding off rust :D
dislexicdime
Post by dislexicdime » 27 Sep 2009 23:39
Me and my girl drove my 71 today then i went to phills and helped him work on his
Dimebag
Post by Dimebag » 28 Sep 2009 22:02
I took my heater control panel to a guy I know with a CNC to find out about getting a new one cut out of some kind of clear/translucent plastic to make a new custom illuminated panel. I hate how it's not lit.
Then I had a new key cut. It works great in the ignition but when I went to lock the door it turned and then got very stuck. I honestly did not think I would get it to turn back to center to release the key, but eventually I worked it and got the key out if the door.
John Thiessen
72 Wagon
Post by goichi1 » 28 Sep 2009 23:16
if you get the heater control figured out, tell him to make two, I want one!!
qwik510
Post by qwik510 » 29 Sep 2009 04:50
Dimebag wrote:I took my heater control panel to a guy I know with a CNC to find out about getting a new one cut out of some kind of clear/translucent plastic to make a new custom illuminated panel. I hate how it's not lit.
IIRC, the 73 heater control is illuminated. Seems like an easy fix. I have one somewhere. I need to di it out and look. My memory isn't what it used to be :shock:
Enjoy The Ride!
David
