Post by funwithmonkeys » 18 Feb 2018 13:00
Did you get your diff cover on Keith?
Post by bertvorgon » 18 Feb 2018 15:16
Car goes into Andy's later in the spring to have it put on and couple of other things. With my shoulder blown out I cannot fight with the exhaust to get it apart to droop the cross member,
danfiveten
Post by danfiveten » 18 Feb 2018 20:13
Not a 510. But i got a 620 in August that ive done alot to. First vehicle ive gotten to build in 10 years since getting hurt. Since i cant do anything to Arts 510, and purple is how i love her from my childhood. It was nice to do this. Just wanted to share, but didnt want to make a entire thread about the truck.
Some shots of Purple and Art.
Vehicles
Art Hughes 1972 Preserved 510
1971 Purple Ratsun 510
2006 AltimaSE-R and 2012 Maxima
1979 Datsun 620
2007 Pathfinder
Post by Byron510 » 18 Feb 2018 20:53
Damn, those wheels look way bigger on your truck than they do on my Armada!
danfiveten
Post by danfiveten » 18 Feb 2018 20:56
That size difference of the body makes them look bigger. 620 looks small against your armada i bet ;)
Vehicles
1979 Datsun 620
2007 Pathfinder
Post by two_68_510s » 18 Feb 2018 22:23
Looked pretty good on the 521 as well.
521 pictures 001.jpg (196.69 KiB) Viewed 2365 times
eastbaysolo_73
Post by eastbaysolo_73 » 27 Mar 2018 21:50
Did this today. With the help of my better half. She helped guid the motor mounts in while I worked the picker.
My build thread
Nor Cal Meng !
Heinrich
Post by Heinrich » 27 Mar 2018 22:07
very cool
eastbaysolo_73
Post by eastbaysolo_73 » 27 Mar 2018 22:10
Heinrich wrote:very cool
Thanks man
My build thread
Nor Cal Meng !
greenthumb
Post by greenthumb » 27 Mar 2018 22:44
two_68_510s wrote:Looked pretty good on the 521 as well.
Now there's a sweet looking 521 :P
Slow painful progress Joel
Post by Three B's Racing » 28 Mar 2018 05:34
Modified my belly pan to add some protection to the front of the SR's oil pan.
eastbaysolo_73
Post by eastbaysolo_73 » 28 Mar 2018 11:07
Three B's Racing wrote:Modified my belly pan to add some protection to the front of the SR's oil pan.
Dam dude that came out sick. Wish I had one of those..
My build thread
Nor Cal Meng !
Post by Three B's Racing » 29 Mar 2018 05:19
Thanks
Futofab sells the belly pans if you need one. But if you have an SR in your 510 then you be cutting. There are certainly i'm sure better options but well, I was bored and we were having a heat wave of 38-40 degs so I got busy.
Post by Byron510 » 29 Mar 2018 06:41
It’s funny how few of these pans are still left on 510’s! If the pan survived the first oil change, it usually was removed when the sway bar was replaced for the performance oreintated driver. The clip the slid under the sway bar mount the held the captive nut which secured the back side of the pan usually didn’t get reinstalled.
Ive been told by many that the installation of the pan does significantly help cooling. But I think most have upgraded to more efficient rads today, with aluminum rads being so common place now.
Nice project just the same Lou, thanks for sharing. Looked like at least a 2 beer job :-)
Post by bertvorgon » 29 Mar 2018 06:51
I like to think I was an efficient DAD......I think I got a badge for that...HEH...HEH...
