Interesting ebay Finds
5teN
Site Admin
Post by 5teN » 11 Feb 2010 14:30
Sticky post for any interesting Datsun related ebay items.
If you navigate to an item that is sold, can you find out what it sold for? I'm not an expert with ebay. Anyways, if so, this thread could be interesting to look back on.
Spencer
heirfaus
Re: Interesting ebay Finds
Post by heirfaus » 13 Feb 2010 11:53
If I remember correctly eBay keeps listings for 30 days after close. After that you can't see anything. You can click "advanced search" and then click "completed auctions" to see the closing prices. We'll just have to update the closing prices in the posts or it will be useless after they are removed from ebay. Would be a nice way to keep track of prices over time.
Corky Bell, Maximum Boost
-defdes
Datsun 1600 510 Race Rally Downdraft L20B Head
Post by okayfine » 02 Mar 2010 08:53
Extensively ported brookfield down draft head with inlet manifold to suit down draft webbers. Can be changed to side draft webers using the manifold face plate as template.
Inlet ports have been moved upwards and straighter and larger. Exhaust ports have been ported as well. Has external water jackets. Estimated cost to replicate $4000+.
Built for a race L20B motor, under 2 litre class. I bought the head with work already done, but then purchased a similar motor complete; so have no use for it.
Comes with inlet manifolds, rocker cover, values (37mm ext, 46mm inlet); but no cam, valve springs, rocker arms.
http://cgi.ebay.com/Datsun-1600-510-Rac ... 335a919c83
Post by Byron510 » 02 Mar 2010 12:48
Hmmmm, Webber horns sticking through the hood. You know, I kinda like the Mad Max appeal of this! :D
brknrekord
Post by brknrekord » 02 Mar 2010 14:00
Byron510 wrote:Hmmmm, Webber horns sticking through the hood. You know, I kinda like the Mad Max appeal of this! :D
This does sound cool!
hang_510
Post by hang_510 » 03 Mar 2010 09:43
:twisted: crazy minds think alike! :lol:
traitorjacknif
Post by traitorjacknif » 05 Mar 2010 19:45
http://cgi.ebay.com/ebaymotors/Rare-196 ... 500wt_1182
1969 Nissan Patrol
Title: Rare 1969 Nissan Patrol KL60
Mileage: 52,000 miles
Vehicle Information
VIN: KL6026838 | See the free Vehicle History Report
Inspection: Order an independent inspection
Warranty: No
Vehicle title: Clear
Condition: Used
For sale by: Private seller
Features
Body type: SUV Engine: 6 Cylinder Exterior color: Green
Transmission: Manual Fuel type: Gasoline Interior color: Tan
Disability equipped: --
Rare 1969 Nissan Patrol with Marks 5 speed transmission in good condition. Only approximately 3,000 Patrols imported to the U.S. I have owned this Patrol for about 2 years (bought in TX) and have driven it less than 2,000 miles. This Patrol runs well and has a strong body. The body is in excellent condition with minimal, superficial rust – only one non-superficial rust spot in back driver side corner the size of a silver dollar. Electrics (fusebox recently redone with resoldered connections and terminals replaced as needed) and lights work well as do all door and window handles and locks. A roll cage was installed in 2008 along with shoulder seat belts for driver and front passenger. Steel brackets also installed in back bed allowing for an alternate back seat seating configuration with one of the two military-style fold down seats oriented frontward with original front seat lap belts utilized as seatbelts for 2 back seat passengers. Add-a-leaf suspension lift with new shocks and bushings was also done in 2008 and new 33x10.50 BFG mud terrain tires (with spare) added. Brakes also recently repaired with two new front wheel cylinders and brake shoes cleaned and adjusted. The odometer lists 52,000 miles but mileage is certainly more given that odometer only has a 5 digit reading. Engine runs well with an upgraded Weber Redline carburetor. Additionally, this Patrol has a very rare 5 speed Marks 4WD transmission with which a previous owner replaced the original 3 speed transmission. Transmission has a “granny” first gear and an overdrive fifth gear allowing excellent driveability over a variety of terrain and vehicle speeds The transfer case and 4 wheel drive system also works.
20% deposit required within 72 hours after winning auction. Balance payoff required by certified check.
Buyer to make arrangements for pickup or shipping. Seller willing to deliver within 30 miles.
Seller can be contacted with serious inquiries only at: 615-545-9936
(*edit I put the actual photos in your post because once the truck sells, the ebay link is lost – Byron)
merlin
Post by merlin » 06 Mar 2010 05:43
i so gotta finish mine!
Merlin from Datsunhistory.com
iceD
Post by iceD » 24 Apr 2010 10:01
Original equipment. Not very sporty, but would work for a restoration.
ice D :|
http://cgi.ebay.com/ebaymotors/Datsun-5 ... 2439wt_992
benz-tech
Re: Datsun 1600 510 Race Rally Downdraft L20B Head
Post by benz-tech » 17 May 2010 19:06
okayfine wrote:Extensively ported brookfield down draft head with inlet manifold to suit down draft webbers. Can be changed to side draft webers using the manifold face plate as template.
I want this and I don't even have an L under the hood
510-Trevor
Post by 510-Trevor » 17 May 2010 20:09
1969 Datsun Z-Series 240
Datsun 240z FRP Body Shell & All Panels - Brand New
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
frp 240 -2.jpg (17.44 KiB) Viewed 15702 times
frp 240 -3.jpg (42.37 KiB) Viewed 15702 times
Full FRP Monocoque Body Tub/Shell
2 x Front wings
2 x Doors
1 x Bonnet/Hood
1 x Boot/Trunk Lid + Spoiler
1 x Front Airdam/Splitter
1 x Dashboard
1 x Bumper Front
1 x Bumper Rear
1972 Yellow 4dr
Post by okayfine » 18 May 2010 07:00
:shock:
Post by two_68_510s » 27 May 2010 18:42
Saw this a minute ago:
http://cgi.ebay.com/MODIFY-DATSUN-510-6 ... 5193128ba2
Very expensive
Post by defdes » 27 May 2010 18:46
I am looking for a copy of this original printing if any one has a spare for a decent price.
Post by okayfine » 28 May 2010 07:03
You might want to set up an eBay search. One just sold last week for $31.
