Interesting ebay Finds
Re: Interesting ebay Finds
Post by okayfine » 25 May 2016 06:17
What's the real quality difference in your eyes?
If you have to space this one out and you have to space the Champion out to make either bolt up, then...?
Post by RMS » 25 May 2016 09:09
hmm besides the koyo being shinier, the drain cock on the koyo rad is at the bottom of the tank not the middle. it has a provision for a thermo switch in the top tank.with the top tank being squared off rather than tapered allows for greater capacity. the welds are straighter and more consistent throughout. the core is evenly spaced between the tanks and appears to be designed from the start to be that size. were as the ebay rad looks like it was once a larger core that was cut down to meet the dimensions.
Post by James » 25 May 2016 09:18
I wonder if the koyo has a slightly different bottom outlet (or if it mounts closer to the front support) as the bay (champion) radiator was essentially interfering with the bottom hose and the alt. pulley. Mine works, but its amazingly tight.
draker
Post by draker » 30 May 2016 23:08
There have been a few people that had those champion radiator crack.. or fail. Even after getting a replacement, it would fail.
The koyo is a bit more. I got mine for about 250 shipped. It fit just fine with the stock alt, and an IR alt. No regrets. Wouldn't recommend the eBay radiator.
71 510 Goon, 71 2 door 510, 69 4 door 510, 92 300ZX TT, 84 720KC 4x4
Post by okayfine » 31 May 2016 05:53
I wonder if the cracking issue is dependent on how you mount it. What are the failure modes?
Yes, you shouldn't have to monkey with the mounting, but with the Champion at least, you do. But, if you do, are there still failures? I mounted mine with rubber sway bar end link bushings, and only tightened three of the four mounting bolts to allow it to expand as necessary.
If it were mounted rigidly to the core support, I could see that being a problem, especially as you'd be flexing the mounting points on both sides since the bracket doesn't mount flush.
draker
Post by draker » 31 May 2016 11:17
They are mounted the same way as stock. Right to the core support with no insulators. The the welds on the tank I believe.
On either the ebay or the Koyo you have to space it out about 6mm to clear the lip on the core support.
Post by 510rob » 26 Jul 2016 10:43
KiKiIchiBan
Post by KiKiIchiBan » 26 Jul 2016 12:21
Wow that's cheap, there is one in the garage with my Coupe somewhere. Maybe they're worth more over here or RHD. Nice RX3 in the background too.
My Bluebird SSS Coupe #25
Post by RMS » 26 Jul 2016 12:35
KiKiIchiBan wrote:Wow that's chea
I was wondering why is it cheep?
very cool looking in a skyline got it on with a celica kind of way ImageImageImage
local 510 showed up on cl this morning http://vancouver.craigslist.ca/pml/cto/5701168915.htmlImage
Im always amazed at how many dimes that are stashed away.
McShagger510
Post by McShagger510 » 26 Jul 2016 20:05
That 510 was for sale around here in East Van for less than half that asking price about 6-8months ago. HA!
'91 Nissan truck
Post by defdes » 17 Dec 2016 09:59
Re: 71 skyline 2000gt-r
Post by RMS » 18 Jan 2017 09:14
surprised to see this auction mentioned in a local news paper : http://bringatrailer.com/listing/1971-n ... 2000-gt-r/ Image
who wants it ? what will it fetch ?
Post by Byron510 » 18 Jan 2017 11:58
Saw that on BaT a few days ago - I'll fetch over 100K I'm sure. I have to admit, it's pretty original. And it's been a while since I've seen one at stock ride height!
Post by okayfine » 18 Jan 2017 17:32
An actual S20 KPG? Yeah, way over $100K. This one hit $190K in August:
http://www.goodingco.com/vehicle/1972-n ... -hakosuka/
McShagger510
Post by McShagger510 » 19 Jan 2017 21:48
Sotheby's $242,000 :
http://www.rmsothebys.com/lots/lot.cfm?lot_id=1067939
Best looking Nissan/Datsun made - big brother 510! Always loved these cars and every year the price keeps gettin' crazier.... *sigh*
Screen Shot 2017-01-19 at 9.42.14 PM.jpg (95.18 KiB) Viewed 1447 times
Screen Shot 2017-01-19 at 9.42.32 PM.jpg (92 KiB) Viewed 1447 times
Screen Shot 2017-01-19 at 9.42.45 PM.jpg (156.16 KiB) Viewed 1447 times
Screen Shot 2017-01-19 at 9.43.06 PM.jpg (70.66 KiB) Viewed 1447 times
'91 Nissan truck
