Additional pics of 510tsunami
510tsunami
Postby 510tsunami » 31 Jul 2012 07:48
I miss spoke about the valance, it's in safe keeping with a bounch aof other parts. Shot showing tubs, engine install and me on the fender. 289 HI-PO with Trick flow heads, engine mated to T5 transmission.
IMG_1253 (Small).JPG (47.29 KiB) Viewed 937 times
IMG_0943_12 (Small).JPG (61 KiB) Viewed 937 times
IMG_1085 (Small).JPG (49.69 KiB) Viewed 937 times
Re: Additional pics of 510tsunami
Postby okayfine » 31 Jul 2012 08:19
510tsunami wrote:289 HI-PO with Trick flow heads
He-Ho! What a tidal wave of torque!!
Seriously though...is this car still in the project phase, or is it a runner? If it's a runner, enough with the pictures, let's get to the videos.
510tsunami
Postby 510tsunami » 31 Jul 2012 08:29
It's still a project, working on rewiring the car currently between looking for interior trim part for the b &c pillars. Went to install the mini hy-tork started yesterday and found out it doesn't fit, so gotta track a proper one down and get it shipped out.
Postby two_68_510s » 31 Jul 2012 09:19
What is happening with the front suspension, you power freaks!!
Is there a Ford pumpkin hiding in the rear?
510tsunami
Postby 510tsunami » 31 Jul 2012 17:46
Joel, u guessed it, there is a 9" pumpkin in the back! Soon I hope to b able to find the weak link (end of year, I'm in the south (Wellington Fl), not really but it's untested so I can only expect some sort of set back. As for the front end the struts are threaded/shortened collars with spacers, it's been near 25 years. Don't remember a whole lot from back then. Right now it's git her on the road mentality and go from there.
Postby okayfine » 31 Jul 2012 17:54
There'll be teething issues, but I doubt you're going to bust a 9" with a FSB.
It's a good-looking setup. What's next?
510tsunami
Postby 510tsunami » 31 Jul 2012 18:13
OKAYFINE
Based on my experience with the design/builder who happened to donate the HP 289 in the engine compartment, teething pains are in between the engine and the ground. We experienced a lot of teething on his Stang which he gave it up. So hopefully he BEEFED everthing up for a street-able version of his dreams! I only hope cause when it hits the ground I want it to continue to rip asphalt and not car parts!
510tsunami
Postby 510tsunami » 31 Jul 2012 18:41
What's next?
Mating a 70 SUN with a Ford drive train (wiring in particular) thers's nooooooo plug and play! Daily contact with a noted aftermarket vendor, it's a work in progress. Then there is the issue of buying parts decades ago and just finding out that they don't fit. S--t o-well, young and stupid I guess or maybe it's just a southern thing (at the time Ft. Laud. Fl.) now Wellington Fl not far from conception!
Anyway, the plans are to assault the asphalt by years end if not sooner!
Postby Byron510 » 31 Jul 2012 22:40
We look forward to your progress between now and then.
Do us all all a great favor, take lots of pics, post 'em here and we'll do our best to keep you motivated.
Return to “General Discussion”
