New potential products for 510's and Datsun from Mattndew76
Re: New potential products for 510's and Datsun from Mattndew76
Ok, that’s Auto correct gone horribly wrong...
Originally asked to update above photos ....
And it’s nice to see the actual parts in your hands - thank Matt for seeing through the errors.
Rob - noted to reread before sending.
John, admittedly that’s pretty funny!
Matt, many would look forward to your various creations that you’ve posted over the years, keep up the good work.
- Mattndew76
I am running some flow analysis on the model I have and cylinder one seems to starve because of the angle.
Gotta change the angle of the air inlet to fan the flow better.
- Mattndew76
Here is a better design for air distribution.
- S14 INTAKE.JPG (223.08 KiB) Viewed 5121 times
How would this S14 maniforld compair to the Getty S14 manifold in $$$ and flow?
- Mattndew76
I don’t know how well a Greddy is as far as flow vs mine. I have to buy a casting and do a flow bench comparison.
Price point on these once I am tooled up and process secure is $1500.00
- Mattndew76
The weld up manifold looking great on a SR22VET
- C66AC20C-811C-4849-8904-17419C61C74A.jpeg (275.57 KiB) Viewed 5041 times
- Mattndew76
More solid work.
- SR20DET-S14 intake manifold v.2-Top.jpg (80.88 KiB) Viewed 4984 times
I'm liking this concept a lot Matt-- keep up the good work-- I have an S14 engine that might need to have one!
Michael Spreadbury
Spriso Motorsports
www.spriso.com
Spriso Motorsports
www.spriso.com
- Mattndew76
Thanks Mike.
I just put in an order for material on the first two manifolds.
Less than I figured but still expensive.
- Mattndew76
Worked on my A12 stuff but I got a little carried away with the plenum volume. Supposed to be 800 CC for optimal response, but I went 1800 by OOPS.
- DP-Intake-3.JPG (106.31 KiB) Viewed 4882 times
- DP-Intake-2.JPG (85.34 KiB) Viewed 4882 times
- Mattndew76
Some assembly required.
- SR20DET-S14 intake manifold v.2-Top.jpg (68.39 KiB) Viewed 4795 times
Very very nice. out of interest,what is the typical machine time on S14 intake Manifold.
- Mattndew76
On my old machine 16 hours of total tool cutting
not too bad, thank you.Mattndew76 wrote:On my old machine 16 hours of total tool cutting
Beautiful work Matthew! Is that SR22 in a roadster?
