New potential products for 510's and Datsun from Mattndew76
Mattndew76
Re: New potential products for 510's and Datsun from Mattndew76
Post by Mattndew76 »
Send them on over. Might be able to cut my work effort in half.
Thanks Guy. :D
KiKiIchiBan
Post by KiKiIchiBan »
RHD steering box brace
www.kikiichiban.com
broke
Post by broke »
mattndew76 wrote:I can make an adapter ring.... But I need the items here in the car lab, or you can make a really well done engineered drawing for me to work from.
I'm ok with making just about anything.
I will have an S15 6 speed on my doorstep in a few days and have plenty of L engine gearboxes to measure. I just have zero CAD ability but can follow instructions and do what I'm told if someone is serious about this? I was wondering if it would be easier to use a automatic L series bellhousing and make a sandwich plate between that and the S15 box.
Also are those moustache bars going ahead for sale? They could be an ideal situation for those of us who aren't legally permitted to weld them for conversions....
-McWicked
toylet
Post by toylet »
All you have to do is swap the bell housing from the 280zx or z l series transmission to the s15 transmission. no adapters needed
broke
Post by broke »
toylet wrote:All you have to do is swap the bell housing from the 280zx or z l series transmission to the s15 transmission. no adapters needed
No, it's a completely different gearbox to the 71C and 71B boxes. So far it's only been done by cutting and shutting bellhousings.
-McWicked
Mattndew76
Anyone interested in weld up manifold stuff? This is a S13 SR20DE manifold I am building. $850.00 for a full kit.
The plenum can be used for several Nissan/Datsun applications.
Post by two_68_510s »
Nice!
eastbaysolo_73
Post by eastbaysolo_73 »
wow thats bad ass. To bad I have a Ka24det and I'm using the excessive manifold. Love your work.
My build thread
Nor Cal Meng !
Mattndew76
SR20DE and KA24DE are the same measurements on runner spacing. I have a KA24DET head flange for this kit.
eastbaysolo_73
Mattndew76 wrote:SR20DE and KA24DE are the same measurements on runner spacing. I have a KA24DET head flange for this kit.
Now your playing with my emotions. How far up does it put the throttle body to front of the engine? One of the issue's i have with my excessive is it puts the throttle body right up on the radiator. I have to run a 90* coupler down which makes it tight for the intercooler plumbing on that side. Not to mention I'm running blow through maf and its on that side as well.
My build thread
Nor Cal Meng !
Mattndew76
EastBay send me a text 541-510-3417
Post by icehouse »
is that a solid works drawing?
Mattndew76
It tis a SolidWorks drawing.
The Plenum flange and Runners are waiting on the bench for the Plenum now.
510tdi
Post by 510tdi »
I've been checking out your thread. Great work!
Post by okayfine »
That's some art, Matt. Please post pictures when you've cut all the parts!
