Having recently pulled the engine from a wrecked z31 for a swap into my DD4dr, are there any parts worth hanging onto before I scrap the tub?
Hubs, Brakes, etc?
Thanks
worth saving
Re: worth saving
Maybe...
Rich - if your ears are on - isn't this the fuel pump of choice for your EFI in tank pump swaps?
Just a thought.
Just a thought.
Re: worth saving
Gas tank with in tank pump and FP relay. You cut the FP mounting ring from the tank and install in the 510 tank.
4 lug front hubs for use with 280ZX front struts and wilwood brakes (Julian did this)
list the rest on Z31 forums. Someone will buy that thing. Do a google search for Z31 forums
Enjoy The Ride!
David
David
Re: worth saving
Thanks David
Re: worth saving
Yea, that's the pump and flange you need. get the fuel cup out of the tank too.
Re: worth saving
As far as the FP relay, I would just go with the CAN-AM bow that Jeff makes and sells, too easy to install and it incorporates a fuel pump relay.
