Exhaust getting into car
2DoorJim
Post by 2DoorJim » 19 Aug 2016 15:13
Do you folks have any issues with exhaust getting inside your car?
My problem seems worse when the windows are down, but if they are up and I turn the fan on or have the vents open it seems to keep the exhaust out. Of course I get no natural AC when the windows are up.
SR20DET and Vee band clamp turbine housing, it shows slight evidence of leakage and I'm thinking I'll cut a thin asbestos gasket ring and to place between the flanges of the union.
I also ordered a cowl seal from Datsport, thanks to Byron for accommodating me on his last order. This is the seal which goes along the rear of the hood. I thought some exhaust leakage from the turbine outlet might have been coming into the car via the perimeter of the hood and through my open window but the cowl seal didn't make any difference.
Ideas?
Re: Exhaust getting into car
Post by bertvorgon » 19 Aug 2016 16:56
hey Jim,
I have had none, but, I did make sure that I extended my pipe a bit out past the bumper, just to make sure any turbulence at the back was NOT going to suck any fumes back under the trunk area. Never have had an issue.
If you have any slight leak in that exhaust/turbine/dump pipe area...it will get into the passenger compartment.
I do not have and engine compartment hood seal.
exhaust pipe
IMGP6329 (Large).JPG (455.88 KiB) Viewed 811 times
2DoorJim
Post by 2DoorJim » 19 Aug 2016 17:05
Keith, I 'm hearing what you're saying, no leaks at all. I might have just slight leaks at two exhaust unions under the pan. I'll address these, and extend my tail pipe another couple inches.
Question for you, where does your crank case breather vent?
Post by bertvorgon » 19 Aug 2016 17:16
Both my crankcase and the valve cover vent to my catch can on the passenger side firewall.
That can is baffled inside but open at the top to atmosphere.
oil catch tank.JPG (278.15 KiB) Viewed 809 times
Post by Byron510 » 20 Aug 2016 23:52
The Bronze will also do this, and as ca as I can tell it's coming in past the trunk seal. The trunk lid is the only panel I didn't test fit on the car, and the back edge sits a bit high. In combination with the old trunk seal, it does leak. I notice the issue most on downhill decelleration. If it'd have installed the back seat or sealed the trunk area from the cabin, it probably wouldn't be an issue. I bought a new OEM trunk seal years ago, still have yeti nine talbot! I still have work to do....
