Billet exterior c-Pillar vents in the works
ecotec510
Re: Billet exterior c-Pillar vents in the works
Post by ecotec510 »
Just wanted to update everyone that was interested. The vents are now for sale. Intro pricing $400 machined finish (straight out of the machine) no polishing. Parts look great, some minor irregularities in the surfacing from using a scan model but not noticable once on a car. Includes gasket and mounting hardware, you reuse your 70-73 baffle duct.
More details on my website http://machinedspeed.com
IMG_20170525_083406 (Small).jpg (116.53 KiB) Viewed 3952 times
IMG_20170525_083345 (Small).jpg (117.49 KiB) Viewed 3952 times
IMG_20170520_065409 (Small).jpg (97.93 KiB) Viewed 3952 times
www.machinedspeed.com
eastbaysolo_73
Post by eastbaysolo_73 »
Wow those look great. Can I ask you what did you use for the gasket?
My build thread
Nor Cal Meng !
ecotec510
Post by ecotec510 »
eastbaysolo_73 wrote:Wow those look great. Can I ask you what did you use for the gasket?
EPDM rubber tubing from mcmaster carr. Mine are designed for the 6mm diameter, not sure what diameter might be best on stock vents.
toylet
Post by toylet »
Can you make them out of stainless?
ecotec510
Post by ecotec510 »
toylet wrote:Can you make them out of stainless?
Sorry, no interest in making any from stainless. Machining stainless is a whole different game than the aluminum.
eastbaysolo_73
Thanks for the info.
My build thread
Nor Cal Meng !
Mattndew76
Post by Mattndew76 »
Why are people wondering about stainless?
Post by RMS »
wouldn't that raise the CG ?
toylet
Post by toylet »
Billet would be hard to keep clean. 510s never had anything billet..wouldn't the stainless vents match all the rest of the trim on the car??
Mattndew76
toylet wrote:Billet would be hard to keep clean. 510s never had anything billet..wouldn't the stainless vents match all the rest of the trim on the car??
Not billet isnt really that hard to keep clean. Aluminum can also be polished and chromed to match the trim.
Stainless is a whole different animal. Machine times would greatly increase. The weight is substantially more than alloy too.
Cmac
Post by Cmac »
Excellent product. look up billet aluminum sealer to protect the vents. The hot rod guys use it on rims etc.
