Momo wheel installed... but difficulties with the momo hub...
shaddai
Post by shaddai » 12 Feb 2020 10:18
Howdy,
I got tired of the ghetto Grant wheel the previous owner installed, so I finally picked up a new Momo wheel and hub. The wheel looks amazing... but the hub was kind of sloppily formed and tight. I was able to get it mostly installed but there's a gap between the back of the hub and the horn wiring/metal piece/thing/whatever you call it... the old Grant hub also had the same issue... so there's no horn functionality.
Anyways... I tightened the s#$@(*& out of the hub to get it installed and as close as I could, but there's still 1/3" or so of a way to go. Thoughts? Is there something wrong with the hub? The steering column? Me?
Did anyone else have issues with the momo hub? Also... the turn signal cancel prongs seem to be rotated 90 degrees from stock. It seems to work okay so far, but it's not perfect. Also... I installed it off by a couple of degrees. Damnit... have to take it off and do it again.
Pics for clicks.
shaddai
Re: Momo wheel installed... but difficulties with the momo hub...
Post by shaddai » 12 Feb 2020 10:19
And it ate an attachment...
Post by bertvorgon » 12 Feb 2020 11:57
Here is a picture of my Momo hub...there is a gap...did you carefully bend the horn power metal strip down a tad to contact the ring?
IMGP7503 (Large).jpeg (369.18 KiB) Viewed 250 times
shaddai
Post by shaddai » 12 Feb 2020 13:05
bertvorgon wrote:
12 Feb 2020 11:57
No... but I will do that.
Fred_L-P
Post by Fred_L-P » 13 Feb 2020 07:07
There's also a gap on mine and I was wondering if it was normal... I thought maybe the column plastic was cut down by previous owners for another hub. I guess it's normal... I did not check if the tab makes contact with the hub.
shaddai
Post by shaddai » 13 Feb 2020 13:00
Okay... I pulled it off, adjusted it (straight was not straight... damn it), and bent the horn connector thing and it's alive now! (don't) Mind the gap?
Post by bertvorgon » 13 Feb 2020 13:08
Glad that worked. I remember when I installed mine I wondered...What the hell!
Post by funwithmonkeys » 14 Feb 2020 20:10
Mine is the same. That is just the way they are. For the turn signal cancel prong I cut mine off the drilled and tapped a hole where it should be and put in a set screw sticking out the correct amount. I got tired of the turn signals canceling as soon as you move the wheel one direction and not canceling at all the other direction.
shaddai
Post by shaddai » 15 Feb 2020 10:56
funwithmonkeys wrote:
14 Feb 2020 20:10
I thought about doing that... but it seems like way too much work...
Post by funwithmonkeys » 15 Feb 2020 11:07
It took 20 min....
