Part Numbers
andrew.lori
Re: RE: Re: RE: Re: RE: Part Numbers
Post by andrew.lori » 04 Oct 2013 07:48
FYI .... Yamaha use the EXACT same nut to hold the wheel hub and axle together in the 2004 Yamaha Grizzly ATV. I bet it's the same on other Yamaha models.
1966 Sunbeam Tiger MK1A
1977 Datsun 200SX Sold :(
1973 Toyota Celica
JordanTr
R200 Differential Rebuild Part Numbers from Nissan
Post by JordanTr » 13 Jan 2014 20:28
Cmac wrote:1987 Nissan R200 seals and Bearings thanks to Chad at Chico Nissan for ensuring they are the right bits.
1 Front seal C8189-N3100
1 Ft Ball bearing 38335-N3220
1 rear roller bearing 38120-06P10
1 mid roller bearing 38120-1320A
2 Side roller bearing 38440-N3111
2 Side seals 38342-N3100
1 Rear cover GKT 38320-N3111
2 Axle Clips 38225-N3100
There is a later style Axle clip that I have not found the part number for it stays on the stub axle were as the part number listed is installed in the diff. center / LSD
toylet
Re: Part Numbers
Post by toylet » 07 Mar 2015 18:49
All below is still available from nissan as of 3/15
Plastic breather 5 speed Z transmission
38322-78000
280zx glove box lock knob(keyed) fits 1970-73 datsun 510 glove box door
68630-P0101
Revised OEM stainless wiper blades for 510 still available from nissan look better than original factory blades.
B6360-A4625 x (2)
Arm rest for B210 fit 510
80940-K1002 x (2)
wiper shaft boots
28890-E4100
placed order
Code Item Qty Price Grand Total
26410-29R01 Lamp-Room Asmy
1 $26.15 $26.15
38322-78000 Breather
1 $1.66 $1.66
27035-21000 Grommet-Heater
2 $0.49 $0.98
65158-A0600 Bumper-Hood
2 $1.84 $3.68
65157-A0600 Bumper-Hood
2 $1.45 $2.90
82865-21010 Rubber
4 $0.83 $3.32
80840-21001 Cover-Drain
6 $1.50 $9.00
B6360-A4625 Blade Asmy-Wind
2 $11.66 $23.32
Subtotal: $71.01
Tax: $0.00
Shipping Cost: $15.81
Grand Total: $86.82
L16 Oil Dip Stick tube
Post by Byron510 » 28 Apr 2015 07:27
Part Number 15146-21002
Also reffered to as a;
GUIDE-DIPSTICK
Oil Guage
510Finn
Re: Part Numbers
Post by 510Finn » 04 Nov 2015 12:16
11061-P0300 HOUSING THERMO LOWER $23.60
25251-37700 NUT (Secures the Temp sender) $3.11
NissanPartsDeal.com (Formerly NissanPartsZone.com)
1972 4dr KA24E-T
1972 Blue WaGoon
toylet
Re: Part Numbers
Post by toylet » 13 Nov 2015 11:45
More goodness... When resealing 510 steering gear box, use Timken 24x35x7 metric seal (summit racing has them)for lower pitman arm shaft. The upper seal is still available from Nissan. Still trying to find the oring...
Fidanza L16,18,20B Aluminum Flywheels with 200mm clutch
Post by Byron510 » 08 Feb 2018 09:17
Yellowcar wrote:200 MM Fidanza aluminium flywheel for a 6 bolt l series crank (L20 TO Z24)
fidanza #143121 for a 77-79 200sx with an L20b (use with roadster clutch and PP)
OK, I needed to add a little revision to this previous post from only a few days ago :-)
I've called Fidanza this past week as my shop mate needed a friction kit for his, and my old 5 bolt L16/18 Fidanza flywheel. paul was concerned as there is no listing for the part in Fidanza's catalog anymore, and even wondered if his flywheel is a Fidanza unit - the later to soon be confirmed. I'm not sure if anyone else ever made an aluminum flywheel for the L16/L18.
Anyways, updated as follows;
PN 143121 - L20B 200mm clutch, 6 bolt flywheel, still in stock as of today
PN 143451 - L16/18 200mm clutch, 5 bolt flywheel, still in stock even though it's no longer in the Fidanza catalog online
Friction kits (come with bolts);
PN 228001 - 200mm dia,16 bolt, in stock - $55 from Summit
PN 228001-20 200mm dia, 20 bolt used prior to 2004, in stock
Currently Fidanza will not sell direct, so you need to go through a dealer like Summit, Jegs, Lordco ect.
Fidanza can be reached at 440-259-5656 and their catalog is here - https://fidanza.com/wp-content/uploads/ ... a-2017.pdf
The lady I talked with said they would continue to make these components for our old Datsuns as there are still requests, and as long as Fidanza can continue to source the ring gears for the flywheels.
So it's good news that the applications most of need are still available.
Re: Fidanza L16,18,20B Aluminum Flywheels with 200mm clutch
Post by Three B's Racing » 09 Feb 2018 05:41
Is it possible you have a Tilton flywheel? Fidanza typically has their name and part number etched on the back side of the wheel. You know you can get the disk resurfaced without removing it. I had it done on one i used to run on my LZ2.2 cost me like $30 easy $$
Re: Part Numbers
Post by Byron510 » 09 Feb 2018 06:37
It’s possible that this is a Tilton, not sure if there were other brands made. But there are no PN’s etched which Fidanza said there would be if it was theirs.
We'll find out shortly if the Fidanza friction plate will work.
Resurfacing wasn’t an option, a ceramic puck type friction disc was used and it chewed the surface right down to the screw heads. I suggested to Paul, for the output that this motor has, to simply use a stock Roadster Nissan disc in the future. It’ll just be easier on things.
Thanks Lou. I’ll let you all know how it goes.
Re: Part Numbers
Post by icehouse » 09 Feb 2018 16:25
Can you guys find me the part number for the steering shaft?
Post by funwithmonkeys » 09 Feb 2018 16:58
Byron I had installed a Fidanza aluminum flywheel on my car back when it still had the L16. I think Robyn has it now. I can look back and try to find the part number.
Re: Part Numbers
Post by RMS » 09 Feb 2018 17:48
if its marked I can go looking for #s
