Part Numbers
RE: Re: RE: Re: RE: Part Numbers
25410-A0601 - fuse block (70-73)
2 door outer moulding
LH = 80821-N1601
RH = 80820-N1601
LH = 80821-N1601
RH = 80820-N1601
Nismo retainer with the cheapass sheetmetal that keeps the SHOE from comming out all the way
otherwise a 9$ part
http://www.nissanparts.cc/cart/?pn=m-13070-n7120
otherwise a 9$ part
- thisismatt
The following are/were still available as of 3/18/2007, on which I got charged $65 for shipping (wtf!):
H0335-89931 Rubbr-glass Run (window channel felt/rubber)
62450-N1600 Hood Top Mouldi (I think I got some of the last ones)
80836-26501 Weatherstrip (inner door rubber/window scraper, left)
80835-26501 Weatherstrip (inner door rubber/window scraper, right)
77720-89908 Screw - Machine
43262-21000 Nut-lock Brg (rear stub shaft axle nuts)
The following were NOT available:
[OUT OF STOCK]1 26555-21600 Lamp-comb Tail $111.23 $84.76 $84.76
[OUT OF STOCK]1 26550-21600 Lamp-comb Tail $110.02 $83.83 $83.83
[OUT OF STOCK]1 80820-N1601 Moulding Rh $34.87 $26.57 $26.57
[OUT OF STOCK]1 80821-N1601 Moulding Lh $34.87 $26.57 $26.57
[OUT OF STOCK]1 76951-A4000 Plate-kick L F $34.97 $26.64 $26.64
[OUT OF STOCK]1 76950-A4000 Plate-kick R F $34.97 $26.64 $26.64
[OUT OF STOCK]1 62310-A8700 A Grille Rad $193.10 $147.14 $147.14
[OUT OF STOCK]1 68210-A5400 Assy Pad Instru $144.62 $110.20 $110.20
[OUT OF STOCK]1 62457-N1600 Moulding Frt Lh $31.95 $24.35 $24.35
[OUT OF STOCK]1 62456-N1600 Moulding Frt Rh $31.95 $24.35 $24.35
[OUT OF STOCK]1 80831-N2120 Weatherstrip $59.05 $45.00 $45.00
[OUT OF STOCK]1 80830-N2120 Weatherstrip $59.05 $45.00 $45.00
[OUT OF STOCK]1 76842-22901 Weatherstrip $78.18 $59.58 $59.58
I'm your huckleberry.
