Part Numbers
bbejj123
Re: Part Numbers
Post by bbejj123 » 14 Nov 2008 10:20
http://www.carpartsmanual.com/datsun510 ... fault.aspx
this was listed in the general section on this site...it shows tons of diagrams and lists the part numbers below it.... enjoy
Radio Lobo
Re: RE: Part Numbers
Post by Radio Lobo » 15 Jan 2009 09:55
Yellowcar wrote:Griffin aluminium radiator (updated link to only show one radiator)
http://store.summitracing.com/partdetai ... toview=sku
Is this radiator for replacing the stock one? Will it work with an sr20 swap?
5andDIME
Re: Part Numbers
Post by 5andDIME » 04 Feb 2009 12:21
part number for Lh fender trim and rubber ? or anyone have one for sale that isnt smashed?
"If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit." - Dr. Emmett Brown
heirfaus
Re: Part Numbers
Post by heirfaus » 11 Feb 2009 14:23
5andDIME wrote:part number for Lh fender trim and rubber ? or anyone have one for sale that isnt smashed?
Last I remember they are unavailable.
Anyone have the number for z22 main bolts?
Corky Bell, Maximum Boost
-defdes
DryHeat
Re: Part Numbers
Post by DryHeat » 11 Feb 2009 15:02
heirfaus wrote:Anyone have the number for z22 main bolts?
The ARP main stud set is the same for the L20 & Z22 ... L20 part number is 12293-18001. Just ordered 10 from local Nissan dealer for around $3.00 each.
Jim Graham
71 Plum Crazy Wagon
datsun510
Re: Part Numbers
Post by datsun510 » 11 Feb 2009 15:07
Better off either running the ARP studs or the factory H/D main bolts part number 12293-V0700. These main bolts are constructed from a higher grade material which allows a 50% increase (to 60 ft/lbs) in the torque setting. They can be installed in any L-series or Naps Z engine. Heavy-duty bolts are marked with a small "12".
Seth
CorAce
Re: Part Numbers
Post by CorAce » 13 Feb 2009 11:15
510ER wrote:27017-B5000 heater control assembly for as per the heater repair sticky
$19.43 from nissanparts.cc
Is this for the valve or the cable?
car more gooder then book
merlin
Re: Part Numbers
Post by merlin » 22 Apr 2009 15:36
got the following from nissan canada today
39628-e4100 bolts 16 at 20.54 dollars each! ouch! these are the halfshaft bolts... no nuts or washers included
65157-a0600 times 4 - about 9 bucks fender hood rests the square ones on the inner fender rail
80836-26501 weather strip times 4 2 door inner weatherstrip for window 6.80 each
h0335-89931 window channle felt - big roll 74.27
80830/31-n2120 2 door door weatherstrip 94.04 each
77720-89908 50 fender screws 55.50
80760-a0600 1`69- door window crank 30.74
76860-a1400 1 rear window latch 51.43
grand total 856.02 and it all fit in a shoebox...
Merlin
Merlin from Datsunhistory.com
Re: Part Numbers
Post by defdes » 22 Apr 2009 16:30
merlin wrote: grand total 856.02 and it all fit in a shoebox...
:!: :o :!:
merlin
Re: Part Numbers
Post by merlin » 27 Apr 2009 18:16
got my second 2 door rear window latch and front window crank today... these are new parts, not NOS.
I also got a interior dome Light, which is brand new , looks great, but not all that stock..
merlin
Re: Part Numbers
Post by merlin » 30 Apr 2009 07:56
checking on availibility for 68 tailight lenses and bumper light assemblies... if they come back available, does anyone want some?
CorAce
Re: Part Numbers
Post by CorAce » 02 May 2009 10:09
centerlink
Federal Mogul
PN# DS849
For the 68-73 510's
You can still get center links from Auto Zone, Duralast $77.
wilderb
Re: Part Numbers
Post by wilderb » 09 May 2009 17:14
does anybody have the part number for 70-73 heater core?
510Martinez
Re: Part Numbers
Post by 510Martinez » 10 May 2009 01:20
CorAce wrote:centerlink
Federal Mogul
PN# DS849
For the 68-73 510's
Is that (assuming here) for the left-hand drive? All I've seen lately are RHD links.
Colbino
Re: Part Numbers
Post by Colbino » 12 May 2009 11:24
Autozone has LHD and RHD centerlinks. They are $91.99, so if you can get them for $77, go for it.
Does anyone have a link for the Federal Mogul centerlink?
