Part Numbers
L24 510
Re: Part Numbers
Post by L24 510 » 20 Jul 2009 18:49
Im looking for the PN's for:
ARP head studs
Head shaver cam tower shims
Rocker arms
valves
72 2 Door with L20. Collecting parts for LZ22 Turbo!
Chadsinto510s
Re: Part Numbers
Post by Chadsinto510s » 21 Jul 2009 08:28
L24 510 wrote:Im looking for the PN's for:
ARP head studs
Rocker arms
valves
I believe the ARP studs are 202-4201 for an L20B
Rocker arms are Nissan PN 13257-W0300
Which valves would you like? Int? Exh? Both? For what app?
Re: Part Numbers
Post by datzenmike » 21 Jul 2009 14:48
I get L16/18 and L20B rockers 13257 21000
Chadsinto510s
Re: Part Numbers
Post by Chadsinto510s » 21 Jul 2009 15:18
datzenmike wrote:I get L16/18 and L20B rockers 13257 21000
That number changes to 13257-W0300. I just left out the supercession chain. :D
Re: Part Numbers
Post by datzenmike » 21 Jul 2009 15:35
Yup, see that now.
L24 510
Re: Part Numbers
Post by L24 510 » 22 Jul 2009 20:22
Im looking for a set of intake and exhaust valves for an A87 peanut. I suppose ill need seats to.
L24 510
Re: Part Numbers
Post by L24 510 » 26 Jul 2009 21:37
Are these the correct main studs for the L20b? same as the L24-28. Incase the link doesnt work PN 202-5406
Chadsinto510s
Re: Part Numbers
Post by Chadsinto510s » 27 Jul 2009 08:09
L24 510 wrote:Are these the correct main studs for the L20b? same as the L24-28. Incase the link doesnt work PN 202-5406
They would probably work but you'd have extra studs left over. The L20B kit is 202-5401 (I believe).
L24 510 wrote:Im looking for a set of intake and exhaust valves for an A87 peanut. I suppose ill need seats to.
I'm drawing a fat blank on what that head came off of. It's monday after all. I'll dig a bit and see what I can find.
Re: Part Numbers
Post by datzenmike » 27 Jul 2009 15:45
Couldn't find a-87 head but if the valve size is:
intake 1.65" or 42mm then try 13201 A1100
exhaust 1.38" or 35mm then try 13202 N0400
These are the valves from the U-67 head.
L24 510
Re: Part Numbers
Post by L24 510 » 27 Jul 2009 20:29
Summit says this part number is for a Sr20 DET
I have yet to measure the actual valve seats but even if the valve size of the head is 33mm EX and 38mm IN. I can have the larger seats put in for the valves.
Thanks for the numbers guys.
Re: Part Numbers
Post by defdes » 27 Jul 2009 21:02
L24 510 wrote: I have yet to measure the actual valve seats but even if the valve size of the head is 33mm EX and 38mm IN. I can have the larger seats put in for the valves.
Do it, you'll like it. :)
Chadsinto510s
Re: Part Numbers
Post by Chadsinto510s » 28 Jul 2009 13:55
L24 510 wrote:Summit says this part number is for a Sr20 DET
From Arp's web catalog:
202-5401 L20 series 4 cylinder
202-5402 2.0L(SR20DE/DET)
Not that there couldn't be a typo someplace on either catalog.
I would ask ARP for the correct # and then order it from Summit.
8008263045 ARP
clean71
Re: Part Numbers
Post by clean71 » 15 Oct 2009 21:55
part numbers for 1968 510 front fender side makers?
1971 PL510 4DOOR AUTO
1969 PL510 WAGON 4SPD
1969 PL510 2DR 4SPD
merlin
Re: Part Numbers
Post by merlin » 16 Oct 2009 06:17
clean71 wrote:part numbers for 1968 510 front fender side makers?
ebay bankok parts... nissan pn is right 26180-23100 left 26185-23100
Merlin from Datsunhistory.com
Re: Part Numbers
Post by Byron510 » 11 Nov 2009 14:37
R180 Taper Roller Bearings for Carrier (Diff side bearings)
NSK 30208 J
$31 each at Kaman Industrial - Delta
I needed to pull one bearing when doing the LSD swap a couple months back (just came across the receipt and thought the info should be here). The new bearings were so cheap that I replaced them both while I was there.
Set diff back lash to .05mm by moving shims around and very slight preload on the side bearings.
