Edit, Just sold.
1971 Datsun 510 wagon
I have spent the last 9 months restoring this car with all the upgrades listed below. Less than 500 miles on the car since the upgrades. There is rust in the rockers but it's repairable, several companies sell replacement rockers. Stock exhaust, but everyone likes a different exhaust so there was no point in putting what I want on there only for it to be too loud or quiet for the next owner.
L20b engine fresh rebuild Dec 2017 less than 500 miles
Datsun W58 intake manifold, 35mm round intake runners sized for head, coolant passage from heads
Hitachi DCH-340 carburetor off 79 620 non CA, electric choke
U67 heads with valve job at engine rebuild time Dec 2017, coolant passage drilled for W58 intake
Datsun square port tri Y exhaust manifold
New hoses, rad upper, rad lower, heater in, heater out.
New aluminum radiator with clutch fan off 79 620 pickup
Matchbox distributor with matching EI coil, ballast resistor removed rebuild by A1-cardon
90 amp internal regulated alternator off maxima.
5 Speed transmission utilizing back short tail from NAPZ truck and L series bell housing, standard H shift pattern (not dog leg)
New shift knob, shift boot.
New clutch, new throw out bearing, new master, new slave cylinder, new flex line Dec 2017.
New Brake Master cylinder
New rear drums, new wheel cylinders, new shoes, new flex line
New front pads, rebuilt cylinders, 2 new flex lines L+R
New sway bar ends, bushings.
New control arm bushings
14 inch steel wheels off 82 Maxima
New Ohitsu 185/65R14 wheels (5 including spare tire)
Aftermarket tach installed in dash, plus extra dash plate to restore to factory look if you don't want tach
New bulbs in dash, turn signals, instrument, new brake light, turn, side marker bulbs
Original seats
New carpet
New front 3 point seat belts
Please no txts or calls before 8am or after 8pm
Asking $6500 or best offer, but be reasonable no low ballers.
in Sacramento, CA
WTS 1971 510 wagon Sold!!!
- 20181014_132217.jpg (349.76 KiB) Viewed 1935 times
- 20181014_132210.jpg (402.4 KiB) Viewed 1935 times
- 20181014_132204.jpg (358.55 KiB) Viewed 1935 times
- 20181004_152813.jpg (324.76 KiB) Viewed 1935 times
- 20181004_152704.jpg (367.01 KiB) Viewed 1935 times
- 20181004_152700.jpg (264.62 KiB) Viewed 1935 times
- 20181004_145737.jpg (582.53 KiB) Viewed 1935 times
- 20181004_145731.jpg (403.4 KiB) Viewed 1935 times
- 20181004_145719.jpg (635.12 KiB) Viewed 1935 times
- 20181004_145710.jpg (603.63 KiB) Viewed 1935 times
Re: WTS 1971 510 wagon
Price reduction $6500 obo
Re: WTS 1971 510 wagon $6500
Sold, thanks for all the interest folks, keep the 510s on the road...
