Datsun 510 & 620 parts<br>
I Have a bunch of Datsun 510 and 620 pickup parts for sale here,
I couldnt get the pictures to load up on here so Ive linked them all to this craigslist page here
http://sfbay.craigslist.org/nby/pts/1614292145.html
Re: Datsun 510 & 620 parts
This item is a voltage regulator.
This intake will only work when bolted to the matching exhaust manifold. It does not have the coolant flow holes in the runners and uses exhaust heat instead.
how much for the seat brackets?
how much for the driveshaft?
pm's sent.
Thanks for clarifying that. I didnt seem to have a problem using the manifold on my L20 thou. I was running a Clifford header with it and the egr tube was connected to the header.
datzenmike wrote:This item is a voltage regulator.
TranzAm wrote:Thanks for clarifying that. I didnt seem to have a problem using the manifold on my L20 thou. I was running a Clifford header with it and the egr tube was connected to the header.
There is a small metal plate clamped between the exhaust and the intake directly under the carb. How did you bolt it on? Have to assume you bolted it on or a backfire would knock it off.
I dont think the manifold you mentioned even has a plate like that on it. I could be wrong thou because at one point I did use one bolted on with grade 8 bolts and the stock gaskets. man, now I'll have to go look
