i've got a few hoods that you could chose from(all metal) if you're interested i live in the interior.
Logan
hood
Re: hood
Hi Logan,SundanceKid wrote:i've got a few hoods that you could chose from(all metal) if you're interested i live in the interior.
Logan
Can you send me a email at elandy@shaw.ca I am very interested in getting a hood .
Thanks
Andrew
I would like to get ahold of a more perfect front chrome peice that goes along the hood.
Also, looking for a set of bump-stops for the hood.. mine sits off to an angle, I don't know if my hood is tweaked or it just needs adjusted. I haven't fiddled with it......
(many apologies, I'm lazy and didn't resize the image!)
Notice how the left side of the hood is a bit lower than the right side?
The right side is correct, but it's about 1cm higher than I'd like it. The left is waaay low. I need to fix it, BUT, I believe it's because I don't have the bumpstops. Maybe as a pro in the hood-field (Muffy!) you'd know how to fix that issue.. is it common? Is it the hood, or the mounts/etc?
Steve Boatman
Grants Pass, OR
1971 510 2DR | KA24DE
Grants Pass, OR
I'm also interested in getting a straight metal hood... send me an email with a pic and info if you have any, thanks. jfast@dccnet.com
