WTB: Rear Window Hardware
pokey
Post by pokey » 31 Dec 2004 08:21
Howdy, anyone have the pieces my brother needs for the rear side window latch? He bought part 20 (see attachment), but needs 17, 18, 21, and the part to the left of part 21 without the part number.
Also, what mounts on the bottom part of the sill? the part below the mystery part to the left of part 21?
Turns out that someone had just screwed his windows shut.
Thanks!
-Paul
I'm not just a normal nerd. I've specialized.
I'm a "Car Nerd"
dean
Post by dean » 31 Dec 2004 08:51
The piece tjhat is located to the left of the #21 is a plastic piece . about 1" long and the window rests on it when closed . i should have those pieces handy , but want 75.00 for # 21 that seems to break alot . let me now if i can help deanos510@hotmail.com
pokey
Post by pokey » 31 Dec 2004 10:36
So is #21 some sort of spacer AND part of the hinge. So 2 pieces?
I'm a "Car Nerd"
dean
Post by dean » 31 Dec 2004 16:38
no the mystery part between 21on the sill , is a spacer !not part of the hinge!
510Freak
Post by 510Freak » 31 Dec 2004 17:32
From what I see the part to the left of #21 is 1 in the same.the plastic aligner is nothing do do with the latch assy at all
pokey
Post by pokey » 02 Jan 2005 15:25
OK, so I'm still a bit cinfused. There seems to be one more piece missing from the diagram. the screw holes in the window part seems to be facing rearwards(tucked under the rubber). So in order to have the latch mount so that it moves inwards, there must be another L-shaped bracket.
So anyone have one of these for less than $75? 2 of the rest of the latch assembly new, was cheaper than that. I'm about to pull out a chunk of steel and a file here... ;)
I'm a "Car Nerd"
