FS:L16 Parts, Megasquirt and rear disk brakes in WI
Jimmer84
Post by Jimmer84 »
Need to clear out some space around here. Many more pictures available. Hit me up with any questions. All prices are Or Best Offer plus shipping from 54162. No (un)reasonable offer refused!
L6 #219 Cylinder Head. Heavily ported and shaved. Larger 1.73 intake and 1.38 exhaust valves. Unknown camshaft. Was checked for cracks and straightness before it was stored. SOLD
L16 A87 Cylinder Head. Stock. Comes with unknown camshaft and aluminum valve spring retainers SOLD
L16 Valve Cover. Comes with cam sprayer bar. SOLD
L16 Valve Cover. Stock. $35
L16 Oil Pan. Reasonably Straight. No leaks. $25
2-L16 Front Timing Covers. One very clean, one not so much. $30 and $20
L16 Gear Reduction Starter. Worked great when I took it out. $40
L16 Flywheel. Stock. $10
L16 Crank Pulley. Stock $10
L16 Water Pump Pulley. Stock $10
L16 Block(white). Bored .030 over. Custom Machined Arias Pistons. Crank ground and Aligned Bored.O-Ringed and has reliefs ground for oversized valves. With 219 head it was at 12.5:1.Has about 500 miles, then head gasket failed, then had it checked, then it sat. I seriously have $1800 of machine work on this thing. SOLD
L16 Block(black). Bored .030 over. Race prepped. O-ringed. $125
Twm Throttle Bodies. 40MM bore. Spacing for direct replacement of Mikuni, Solex and Weber Carbs. Comes with all fuel line adaptors, fuel rails, TPS, 180cc/min injectors, and air filters $700
Megasquirt V2.2. Older but worked great. Does fuel and spark. Comes with Harness, Sensors and computer cable. Harness has weatherpack connectors and waterproof/sealed crimp splices $125
L16 Distributor with Pertronix installed. $40
Summit Racing CDI Ignition Box. $65
MSD Blaster 3 Coil. $25
Ford EDIS-4 Ignition System. Comes with 2 Ignition Modules, Coil and Wires. Needs Pickup wheel and crank sensor. $40
Rear Disk Brakes. JFZ Brand 2 Piston Fixed calipers. Can still get parts from Sierra Racing Products. 2 Piece Rotors. I get replacement rotors from Coleman Racing for $75 each. Comes with weld on bracket for rear control arms. $275
Driver-Gravelspec Rallysport Datsun #510
www.facebook.com/gravelspec
Dal
Re: FS:L16 Parts, Megasquirt and rear disk brakes in WI
Post by Dal »
Interested in the 219 head. Sent PM
Cheers,
Dal
Jimmer84
Post by Jimmer84 »
Bump for new LOWER PRICES! And sold items.
Jim S.
