This is a spare Nissan Comp (I believe) header I've been holding on to. $150 + shipping
NOTE: It IS used and not perfect. Note repair (done well) on one pipe and each pipe has a hole in it for EGT probes. Those would need to be welded or clamped off if you aren't using EGT probes. Don't get excited about the finish. I sprayed it with cold galvanizing compound which helps keep it from getting yucky in storage and won't flake like paint when run but it isn't a ceramic coating.
Comp Header
Comp Header
- Comp Header Side.jpg (30.04 KiB) Viewed 3084 times
- Comp Header repair.jpg (18.6 KiB) Viewed 3084 times
- Comp Header other side.jpg (26.96 KiB) Viewed 3084 times
