I need a cluster shaft for the RWD FS5W71C transmission for the SR20DE or DET mine rolled off my bench and chipped some teeth F@#K! The gearing count is as follows.
1st: 14 teeth
2nd: 20 teeth
3rd: 28 teeth
I don't need the 4th gear as I can remove mine and use it but if its there and you don't want to remove it thats fine also. Cash or trade works for me.
Thanks
Lou
Wanted SR Trans Cluster shaft
Re: Wanted SR Trans Cluster shaft
There is no 4th 'gear' on the counter shaft or anywhere else. Fourth is a solid connection from clutch to driveshaft along the mainshaft. The removable gear on the front is how the counter gear is driven by the gear above it on the mainshaft.
Do you know the gear ratios for 1,2,3? The S14 uses
1st.... 3.321
2nd... 1.902
3rd... 1.308
4th... 1.000
5th... 0.759
Easier to just swap your front case onto a 240sx box
1st.... 3.321
2nd... 1.902
3rd... 1.308
4th... 1.000
5th... 0.759
Mike if you look at a cluster shaft it goes like this, little gear is 1st, 2nd it the next biggest and so on. 4th gear is on the end of the shaft next to 62mm bearing, that is the only removable gear.datzenmike wrote:There is no 4th 'gear' on the counter shaft or anywhere else. Fourth is a solid connection from clutch to driveshaft along the mainshaft. The removable gear on the front is how the counter gear is driven by the gear above it on the mainshaft.
1st.... 3.321
2nd... 1.902
3rd... 1.308
4th... 1.000
5th... 0.759
Anyway yes 1,2,3 gear is as you stated
It is easier to swap front case on a 240 trans, but have you seen what people are asking for a 240sx trans + shipping? cheaper to rebuild where I live anyway.
