1972 2DR shell part out
Re: 1972 2DR shell part out
What is the condition of the right front inner wheelwell. Complete from the door hinge post to the front?
How about the radiator support?
- Support.JPG (66.27 KiB) Viewed 5051 times
Update,
The car has been cut in to pieces and a lot of it has been sold but there is still some left.
Cowl and A pillars, $80.00 or I can cut to suit.
Frame rails $100.00 each
Firewall cut to suit PM for price,
Rear floor's Dr. $30.00 & Pass. $40.00 ( with brace and some tunnel )
All prices plus shipping.....
Any update on the front radiator support? I am also interested in the front floor pans, if they are in good shape. Trying to look at the last picture from the post above, maybe just buy the front half of the car?
Here is 2 picture's of the core a couple months ago, the rightside air channel a fender flange has been removed since then.sgplancer wrote:Any update on the front radiator support? I am also interested in the front floor pans, if they are in good shape. Trying to look at the last picture from the post above, maybe just buy the front half of the car?
I need the front right unistrut frame from just behind the tension control mount up the wheel well 4" then towards the front across the front of the wheel well into the panel out to the front. Then from the front of the tension control mount 8" in towards the center of the radiator support all as one piece. Is this possible? if you need a better discription let me know.
Thanks
Thanks
That is basically what I was asking for too. I even offered to purchase the front half of the car. I haven't heard back from the seller, so hopefully he will get back with one of us. Good luck!Three B's Racing wrote:I need the front right unistrut frame from just behind the tension control mount up the wheel well 4" then towards the front across the front of the wheel well into the panel out to the front. Then from the front of the tension control mount 8" in towards the center of the radiator support all as one piece. Is this possible? if you need a better discription let me know.
Thanks
I will gladly sell you the front clip, the dr. floor pan has some pin holes. please let me know what you need for us to proceed. I never heard from you after posting photos or the core.sgplancer wrote:That is basically what I was asking for too. I even offered to purchase the front half of the car. I haven't heard back from the seller, so hopefully he will get back with one of us. Good luck!Three B's Racing wrote:I need the front right unistrut frame from just behind the tension control mount up the wheel well 4" then towards the front across the front of the wheel well into the panel out to the front. Then from the front of the tension control mount 8" in towards the center of the radiator support all as one piece. Is this possible? if you need a better discription let me know.
Thanks
Thanks,
anything left?
Yes, here's whats left.....
1. Front clip ( Sold some dr. floor & frame rail pieces )
2. The wind shield surround and cowl
3. The rear floors
4. The steering column and steering box
5. Rear upper seat cushion hooks
6. '70 > '73 lower dash brackets ( located on a pillars )
3. The rear floors
pm sent
What about this piece?Three B's Racing wrote:I need the front right unistrut frame from just behind the tension control mount up the wheel well 4" then towards the front across the front of the wheel well into the panel out to the front. Then from the front of the tension control mount 8" in towards the center of the radiator support all as one piece. Is this possible? if you need a better discription let me know.
Thanks
Three B's Racing wrote:What about this piece?Three B's Racing wrote:I need the front right unistrut frame from just behind the tension control mount up the wheel well 4" then towards the front across the front of the wheel well into the panel out to the front. Then from the front of the tension control mount 8" in towards the center of the radiator support all as one piece. Is this possible? if you need a better discription let me know.
Thanks
PM sent
