WTB - Dogleg
MRLQ2U
WTB - Dogleg
Postby MRLQ2U » 02 Feb 2017 08:56
I know this is a stretch, but I'm hoping to find a shortie L-series dogleg. Converting a '72 4dr 510 w/L20B from automatic. Need clutch pedal, shifter and fork also.
I've seen too many code variations to be sure which is right...but the one I'm looking for is FS5*63A (not sure if the * is a W or a C).
Lemme know whatcha got.
Thanks
LQ
Re: WTB - Dogleg
Postby RMS » 02 Feb 2017 14:21
I have a nib dogleg .....$1500ca local pickup only richmond bc ca...I may be able to get it into blaine wa on the cheep
complete petal assembly $120ca
Re: WTB - Dogleg
Postby Three B's Racing » 03 Feb 2017 08:07
MRLQ2U wrote:I know this is a stretch, but I'm hoping to find a shortie L-series dogleg. Converting a '72 4dr 510 w/L20B from automatic. Need clutch pedal, shifter and fork also.
Thanks
LQ
Yeah $1500 is a bit steep unless of course it's been rebuilt. Why a dog leg, to avoid shorting driveshaft? I'd look for a trans from a truck, 280z/zx and the like that can be had for $300-$600 but naturally their being used bring a certain amount of risk.
Just my opinion
Re: WTB - Dogleg
Postby Three B's Racing » 03 Feb 2017 08:10
RMS wrote:I have a nib dogleg .....$1500ca local pickup only richmond bc ca...I may be able to get it into blaine wa on the cheep
Doh! just saw the NIB, SO!! yeah $1500 for a new in box is a good deal. But I gota ask does it have lube in it and if not has it been sitting with no lube? and could internal rust possibly be a factor? I've seen rusty internal fro sitting trannies before so,,,,,,,
Re: WTB - Dogleg
Postby RMS » 03 Feb 2017 08:34
I had not considered that it may not have any protection from corrosion....my military stuff is always covered in cosmoline.
some may remember my nos 1000 and 1200 parts that came from southside nissan when they were unloading stock back in the late 80s early 90s. this transmission is from the same buy. it is not in a box but in a bag. this afternoon I will remove it from its resting spot in a warm dry barn filled with oak chairs and tables. I will try to gain access to a borescope then make a small incision in the bag and get some pics of the inside.
MRLQ2U
Re: WTB - Dogleg
Postby MRLQ2U » 03 Feb 2017 09:53
Great point Three B's...I'm PMing with RMS. I'm sure he'll verify that condition for me. I plan to autocross/hillclimb the car and the track and hills I run on are all 2nd and 3rd gear. I used a dogleg in an 510 I had many years ago and I absolutely loved the pattern.
Len
Re: WTB - Dogleg
Postby RMS » 03 Feb 2017 12:17
because of the snow the scope will have to wait till monday
Re: WTB - Dogleg
Postby datzenmike » 03 Feb 2017 16:25
FS5W63A The W is for Warner style syncros.
Pro.... has exact same 1,2,3 gears as stock 4 speed but a nice reasonable 15% overdrive. Same length as stock 4 speed. Adequate strength. Ideal reverse above first for rocking car stuck in a snow drift.
Con.... trans mount needs modifications. Trans not that plentiful/common.
FS5W71B
Pro... wide, mid and close ratio gear choices. Overdrive from mild to wild. Extra strong, built to handle inline six cylinder L28s. Very common/cheap in '77 and up z and early zx, 810/Maxima through '84 and 620 and early 720 trucks.
Con.... trans mount needs modification, driveshaft shortened.
Never understood the dogleg fascination for an around town car. I prefer a good straight shift into second and presume the dogleg is no different than the awkward 2 to 3 shift in a regular H pattern transmission. On the track, never using first would be fine, but not so much in town. Also I like the over drive shift location right and forward out of the way rather than over by the passenger seat. Highly recommend the mid ratio 71B. I have one (first year 280zx mid ratio) but I swapped an '85 720 diesel tail on it. Mostly for the raised fulcrum point short shifter but after '80, all 71B have a reverse check sleeve in the tail that prevents a down shift from 5th into reverse just below it. I do have a long (31.5") dogleg minus the front and rear cases. This would have been available only in Japan and the 610SSS? in Australia
MRLQ2U
Re: WTB - Dogleg
Postby MRLQ2U » 05 Feb 2017 16:31
Thanks datzenmike - I appreciate the feedback.
MRLQ2U
Re: WTB - Dogleg
Postby MRLQ2U » 05 Feb 2017 16:33
I can put this to rest. This problem has been solved! Thanks all.
Return to “Classifieds”
Users browsing this forum: No registered users and 7 guests
