WTB: Rear coilovers and other stuff
mattyhacks71
Postby mattyhacks71 » 22 Apr 2017 11:57
Looking to buy various things if I can find them used.
-Rear coilovers
-Adjustable LCAs
-Adjustable TC rods
-Bump steer spacers
-Rear bumper (Good luck right)
Thanks Realm!
zKars
Re: WTB: Rear coilovers and other stuff
Postby zKars » 22 Apr 2017 15:24
I have a set of rear coilovers available. Got them from poorMtNkid couple of years back. They are for a significantly lowered 510 however and can't work for me. Koni shocks, Eibach 300lb springs. $400 CDN. I paid that $USD.
I also have a rather ancient and "interesting" but servicable pair of adjustable T/C rods. $40 for the pair
Pictures coming.
zKars
Postby zKars » 22 Apr 2017 15:28
zKars
Postby zKars » 22 Apr 2017 15:31
The T/C rods have a 5/8 spherical rod end in there and a threaded T/C rod to match. Pretty good solid design but you can't adjust them without removing one end or the other.
Since the OD of the TC rod is apparently the perfect size to just thread to 5/8-18, seems like it would be easy to make a stock set into an adjustable set with a simple hex turnbuckle coupler pretty darn easy. Assuming you had a LH and RH die handly. Byron....
mattyhacks71
Postby mattyhacks71 » 22 Apr 2017 19:01
^ Sent you a PM
Return to “Classifieds”
Users browsing this forum: Google [Bot] and 6 guests
