rear Maxima Brake Calipers FS
ajen68510
Postby ajen68510 » 02 Jul 2017 11:41
Rear Maxima Brake calipers , Brand new, With pads . Bought for the EDP brake upgrade but brackets did not fit , still have the brackets ,but wont sell as they are wrong. I have the brake lines that fit this caliper also (new)
Tokico Calipers L & R - 30.00
Brake Lines 20.00
Maxima Brack caliper.jpg (40.27 KiB) Viewed 679 times
toylet
Re: rear Maxima Brake Calipers FS
Postby toylet » 03 Jul 2017 06:11
I had the same issue with his brackets.. cant believe he is still selling junk.
ajen68510
Postby ajen68510 » 03 Jul 2017 06:55
Ya, i just figured some might need these as spares from the old days when they did work. I've moved on to a system that does work.
Postby Byron510 » 04 Jul 2017 07:47
Which caliper brackets were these that did not fit?
And I'll assume that the Maxima calipers are different in either bolt mounting or offset from the 280ZX calipers?
deano510
Postby deano510 » 04 Jul 2017 10:52
The offset and rotor diameter are the difference.
Dean
ajen68510
Postby ajen68510 » 04 Jul 2017 15:31
Byron510 wrote:Which caliper brackets were these that did not fit?
This was 200sx Rear rotors, Maxima Calipers , The instructions i had were from "Engineered Datsun Products" , Brake lines from techna-fit p/n DM-RCONV, both Peter and myself tried to put them together to no avail
DADZSUN
Postby DADZSUN » 07 Jul 2017 14:58
Could be perfect for my 280z project.
You've been PM'd.
'72 Datsun 510 - KA24E/R1 carbs/EDIS 4 Megajolt
'76 Datsun 280z
ajen68510
Postby ajen68510 » 07 Jul 2017 17:21
sent u a PM reply
ajen68510
Postby ajen68510 » 08 Jul 2017 08:40
No Takers. heading to dump with a bunch of stuff. Thought someone could use them. Need the shelf space.
ajen68510
Postby ajen68510 » 08 Jul 2017 16:03
Saved in 11th hour, gone to home in Ottawa
Return to “Classifieds”
Users browsing this forum: Yahoo [Bot] and 10 guests
