stand alone coil packs Electromotive
Postby icehouse » 04 Jul 2017 12:21
This stand alone ignition system runs off a crank trigger and allows you to program the timing curve. It also has a rev limiter setting. The pickup bracket was made for a Z24 block but had a L series head, so I'm not sure if all the L blocks have the same casting or not, some modification may be required. It has a remote that can be mounted the car to adjust the timing on the fly. There is also a modified distributor to support the oil pump drive shaft. $250 or trade
Return to “Classifieds”
Users browsing this forum: No registered users and 8 guests
