#1157 Plasma LED RED bulbs for sale
Post by bertvorgon » 27 Jul 2017 07:43
After many, many years of trying to get a better bulb in our rear tail lights, the brake and running light #1157, I have finally found one that more than fits the bill.
I have imported in a bunch of them, McShagger & Funwithmonkeys will attest to them.
I also put a set into my vintage Boler trailer, what an amazing difference.
These bulbs light up as RED and in our aged rear taillights, make an incredible increase in brightness, and being PLASMA LED, light up instantly with the brakes!!!!!
These are the real deal but are not cheap, I am selling them at $22.00 CDN each. ( local only)
Re: #1157 Plasma LED RED bulbs for sale
Post by icehouse » 27 Jul 2017 12:33
We don't get a picture of a 510 tail light with one side stock and one LED?
Post by bertvorgon » 27 Jul 2017 12:52
YES..James and I were going to do that!
Make sure your sun glasses are on.
Post by James » 27 Jul 2017 13:12
Would you be willing to share what they are - for those of us who are not local?
Post by bertvorgon » 27 Jul 2017 18:07
Jeez...I dunno.....my Empire could be in jeopardy.....
Lets wait till we do the comparison, so you can all see they really are good. Then we will go from there.
I have I think 8 sets left as they are flying off the shelf.....
66DUCE
Post by 66DUCE » 28 Jul 2017 13:35
Hey Keith so these ones have a built in resister? If so could you bring a set tomorrow for me?
Thanks
Post by bertvorgon » 28 Jul 2017 13:47
I do not know, but, yes, I will bring a few sets tomorrow.
Would that let them work with a stock flasher?
66DUCE
Post by 66DUCE » 28 Jul 2017 16:36
Yes the cheap ones do not have the same resistance as the old incandescent bulbs and in a circuit that incorporates the turn signal the signal will flash fast.
dscottdatsun
Post by dscottdatsun » 28 Jul 2017 18:45
66DUCE wrote:Yes the cheap ones do not have the same resistance as the old incandescent bulbs and in a circuit that incorporates the turn signal the signal will flash fast.
Unless you switch to a non-mechanical flasher unit
Post by bertvorgon » 28 Jul 2017 19:26
Post by RMS » 28 Jul 2017 20:31
.....but then you don't get the classic bink bonk noise :cry:
ajen68510
Post by ajen68510 » 29 Jul 2017 07:57
66DUCE wrote:Hey Keith so these ones have a built in resister? If so could you bring a set tomorrow for me?
Thanks
Just switch to a electronic flasher. Or add a 3K ohm resister. I found it works perfect with a 10 dolla electronic flasher unit
Post by bertvorgon » 29 Jul 2017 17:07
The response to these bulbs has been overwhelming to say the least. Everyone that has bought a set is more than pleased with them.
I am going to go through all my Pm's in order of request, will fill with what I have left, which is not many at this point. I will order more if that is the case. So you know, I am not in this to make a ton of money but cover cost and put just a few extra bucks in my pocket. My main mission was to get a really good bulb for our aged tail lights, brake and running, so our 510 community benefits!
With the response I have had, and even more so to check it out, I am going to spec out an 1156 bulb and see what that is like with our rear turn signal.
ajen68510
Post by ajen68510 » 29 Jul 2017 17:40
bertvorgon wrote:The response to these bulbs has been overwhelming to say the least. Everyone that has bought a set is more than pleased with them.
I am using the 1156 LED bulb from VLED (Similar prices as yours, your price is a bit better). Its spectacular. U should spec out reverse white bulbs also,
Post by bertvorgon » 01 Aug 2017 12:59
If Derek, Hank and Jordan take their lights, I will have 3 sets left.
