Datsun 1200 coupe trade for a 510
robch215
Postby robch215 » 04 Aug 2017 08:53
I have a datsun 1200 coupe that i would love to trade for a 510 if someone would be interested.. i am from Quebec Canada
The car run and has new parts, it still has some little things to do
-new s13 front disk converson
-new rear cylinder
-new brake master
-new clutch master
-new clutch slave
-new alu fuel tank installed under the car in the oem spot
-new momo hub
-carb rebuild (need fine tuninf probably)
-stock a12 with 4 speed trans,
-headers with straight exhaust
-Civic SI seats
I have almost another car in parts (shell, body, diff,suspension,grill, and a lot more). On the car is bolted trans mount, i had them made by laser cutting, cnc bended and tig welded because the previous owner removed the oem ones for a bigger trans.
Bad
-driver floor will need work
-no trunk seal (will order one this weekend)
-used duct tape arround the trunk and backglass so the paint will be damaged(yeah i know, i didn't care because i want to redo the paint another color)
I am looking for a 2 or 4 doors, arround the same condition as mine, would consider a clean complete shell (missing motor and trans) but would need to be close for the transportation
robch215
Re: Datsun 1200 coupe trade for a 510
Postby robch215 » 30 Sep 2017 10:00
Up
Return to “Classifieds”
Users browsing this forum: No registered users and 7 guests
