Canadian510
Post
by Canadian510 » 30 Jan 2018 18:55
Have an entire sr20ve short block left over after robbing the head/front cover off it, figure somone might want the pistons for a high compression NA build. The VE pistons in a DE block will give you 10.3:1 compression.
Engine supposedly had 65,000km on it, no nasty surprises or warning signs as it came apart. Bottom end is still together as I had someone who said they wanted it but backed out. If there's any interest I'll pull it apart and send pictures. If you need anything else off it or any random DE parts might have them kicking around.
Looking for $60 for the pistons.
