SOLD
boggie1688
SOLD
Post by boggie1688 » 20 Apr 2018 07:55
Up for sale is a brand new R160 finned diff cover. Machined for increase diff fluid volume and finned for increased cooling. Note the drain plug design, most R160 covers don't drain completely, the drain hole is completely flush with the bottom of the cover. 300 shipped within contiguous USA.
I originally bought this cover from Matt, a member on these forums. The plan was actually to use it on a R160 diff inside of a 2015 WRX. The project was to pull the open diff pumpkin, and dropping in a clutch lsd, then using the diff cover. Long story short, it took almost 2 years for me to get this buttoned up. When I finally did and tried to install the diff, I realized the fins were cut too long and interfered with the crossmember. I thought about machining the fins down (see the sharpie marks), however I realized that to clear the crossmember I'd need to machine too much fin material and it would open a hole into the recessed cavity inside the cover. Booo, a easy fix if I knew before ordering the cover.
In any case, I'm returning to the forum to sell this cover to a 510 owner. The studs have been installed as well as the vent tube. Note there are nicks around the vent tube from me installing a new vent design found on the 2015 WRX R160 diff. The vent didn't sit all the way down, and I had to pry it back out and lathe it down to fit. There are also nicks around the cover, just from general handling. Otherwise the cover has never been installed on the car. The diff was final assembled, so the cover is known to fit the R160 100%.
Photos can be in the google album: https://photos.app.goo.gl/xli0LBcBSj2bw6Kk2
Really wish I could have used this cover. I hope it goes to someone who appreciates the craftsmen ship.
Also, I know this is my 2nd post on the forum, so for what it is worth here is my ebay profile: https://feedback.ebay.com/ws/eBayISAPI. ... boggie6868
Here is my Nasioc itrader profile: https://forums.nasioc.com/forums/itrader.php?u=165955
P.s. I also got a few R160 diffs in various stages of disassembly. If you are looking for ring gear, case, etc let me know. :D
dgale914
Re: FS: Billet R160 Finned diff cover $300 shipped
Post by dgale914 » 20 Apr 2018 11:00
Sent PM about the cover....
Doug
boggie1688
Post by boggie1688 » 20 Apr 2018 13:18
Sold
grimlid
Re: SOLD
Post by grimlid » 21 Apr 2018 09:11
That thing is sweet! Sorry I missed out.
Didn't your Mom ever tell you, " nobody likes an a__hole?"
