WTS Bill Partridge has discounted parts for liquidation
bpart3
Post by bpart3 » 06 Jun 2018 15:17
1. AP 7 1/2" Competition 2 plate clutch $100
2. 240Z type Caliper new $25
3. Heavy Duty AP pressure plate $30
4.(2) Solidhub friction plate 7 1/2" $20 each
5.6 bolt L series aluminum Fylwheel $100
6. (2)shallow front wheel rotors 10 1/2" for 510??? $$25 each
7. (2) deep front wheel rotors 10 1/2" for 510 or 240 $25 each
8. 12"Nissan 6 bolt aluminum flywheel $100
9. 12" stock steel 5 bolt flywheel $10 each
10. 12" flexplates $10 each
11. 71/2" stock heavy duty clutch plate $20
12. (13) engine/trans separator plates $3 each
13. (4) coleman 10" brake rotors new in box $20 each
15 solid steel comp flywheel 6 bolt $20
16.solid steel flywheel 5 bolt $20 each
17 Ring gear for small flywheel $10
18.(2) floating axel hub covers aluminum $20
19. (2) floating axel hub and brake disc covers aluminum $30 each
21. Aluminum rear differential cover $5
22. MSD ignition kit (coil and wires etc) $300
23 MSD misc parts grab bag $15
25. Nissan stok starters $10
26.(4) Wilwood 120-6806 brake calipers new in box $40 each
27.full float solid rear end axle from 510 wagon$50
28. 510-adjustable front camber plates $20 each
29.I-O port roll bar camera mount $40
30. TDC formula car 2 stage dry sump pump$300
31. (4) L-16 front covers $10 each
32 Heavy Duty L-16 /L24 water pumps $20 each
33. L-20 front covers $20
34 (4) Coilover Carrera shocks $40 each
35. :-4 nissan dry sump pan project.$20
36. Nissan gear reduction starter$50
37.L-16-L-18 (using normal racing head)4-1 tubular exhaust manifold$50
38.4-1 tubular headers (needs collector)$20
39. (12) custom short billett aluminum air horns for 44 weber carbs $10 each
40.ARE aluminum dry sump pan like new $250
If you want to bundle several parts and combine shipping we can discount
Local pickup on large items suggested
Re: WTS Bill Partridge has discounted parts for liquidation
Post by Byron510 » 06 Jun 2018 16:40
Pm Sent
GREG510
Post by GREG510 » 07 Jun 2018 00:44
Where are these parts Located at?
bpart3
Post by bpart3 » 07 Jun 2018 04:40
The parts are located near Indianapolis, Indiana. where are you located ?
DAT510Z
Post by DAT510Z » 08 Jun 2018 16:33
PM Sent
jay123
Post by jay123 » 09 Jun 2018 08:22
PM sent
'72 510 2dr getting li'l luv..
JimITC510
Post by JimITC510 » 14 Jun 2018 12:10
Bill,
- I am interested in some parts you have for my SCCA ITC 510.
- AP 7 1/2" competition 2 plate clutch for $100. Will this fit in a stock bellhousing? Used or new?
- AP pressure plate for $30. Does this go with the 7 1/2" clutch? Used or new? Do you have a TO bearing for the trans shaft?
- What is the weight of the aluminum fly wheel?
- Stock steel flywheel for $10 as I want to severely balance another flywheel to come close to the weight of the aluminum flywheel and replace the stock flywheel in the car.
- Do you have any stock engine parts - head, oversized pistons, crank?
What state are you in as I travel from FL to New England a few times a year and can pick up.
Jim Bell
jimjeanbell@gmail.com
JimITC510
Post by JimITC510 » 14 Jun 2018 12:11
Bill,
Forgot to ask, do you have a stock steering box in good shape?
Jim
