Rear Axles
ray23
Rear Axles
Post by ray23 » 28 Sep 2018 15:09
looking for someone selling rear axles in Southern California for a 72 510 s dr. thanks in advance
Ray
72 Datsun 510 2 door
86 Ford F250 extra cab 6.9 turbo Diesel 2WD
toylet
Re: Rear Axles
Post by toylet » 30 Sep 2018 20:21
I got them in AZ
Re: Rear Axles
Post by Byron510 » 01 Oct 2018 06:18
I recently ended up using a set from a 280ZX as my 510 stock was also gone.
Since I have an older type R180 with the Bolt in style stub shafts, I used a pair of 280ZX half shafts that have the spline right on the inner end of the inner half shaft U joint. It eliminated 2 flanges and 8 bolts out of the system.... 8 bolts I don’t have to worry about checking anymore on a regular basis!
For years I’d been throwing these away when I parted ZX’s. But when it came down to it, I looked at the design and realized it really is better than the two flange system.... clarity after all these years :-) Age is a funny thing. Good luck with your search, hopefully this helps.
yenpit
Re: Rear Axles
Post by yenpit » 01 Oct 2018 16:10
Byron.........was the long center bolt "captive" in the stub axle, unless you disassembled the u-joint? If so, I have a set + 2 ZX parts cars!
TJ
72 510 4dr
80 720 pickup
LOTS of parts!
2000 Impreza Outback Sport
2002 Forester
yenpit
Re: Rear Axles
Post by yenpit » 01 Oct 2018 16:31
ray23.....saw your other post...........do you need the STUB axles at the outside where the rear wheel bearings are? If so, maybe look for a pair of good control arms with good wheel bearings, cuz swapping out the outer STUB axles is a royal pain in the rear!!
72 510 4dr
80 720 pickup
LOTS of parts!
2002 Forester
ray23
Re: Rear Axles
Post by ray23 » 01 Oct 2018 21:41
got the bearings out already and ready for a new set, but one axle is all FUBRD from the previous owner. I'm picking up a set tomorrow, so i can finish the install.
Ray
Re: Rear Axles
Post by Byron510 » 02 Oct 2018 07:52
yenpit wrote:
01 Oct 2018 16:10
TJ
Yep, the long bolts are captive in the 280ZX stub axle, and there's a little O ring on the bolt as well to seal it from leaking oil - just like the 510 bolt.
I too pulled these recently from a 280ZX rear set up, which is why they were kicking around.
It's a bit of a pain to get the bolt started, I'd certainly recommend you start at the inboard end and then bolt on the flange at the outboard side to your LCA stub axle. In this way you can move the axle to one extremity and give yourself some more space.
Honestly, I can't think of why I wasn't using these before! They make more sense for sure.
yenpit
Re: Rear Axles
Post by yenpit » 02 Oct 2018 08:42
Cool thanks Byron!
Good luck with the project ray23! 8)
72 510 4dr
80 720 pickup
LOTS of parts!
2002 Forester
deano510
Re: Rear Axles
Post by deano510 » 08 Oct 2018 10:51
I have these in NOrCal.
Dean
DADZSUN
Re: Rear Axles
Post by DADZSUN » 11 Oct 2018 17:21
I've developed some direct bolt-in CV axles for 510.
Servicable, reliable, and beefy enough to handle at least 220 ft/lbs.
I'm just wrapping up testing and they should be available in a few weeks.
www.datsunrestomods.com
zKars
Re: Rear Axles
Post by zKars » 12 Oct 2018 07:22
I'm liking this! Let me know when you need a tester! I'll try my best to make them fail.
Camano510
Re: Rear Axles
Post by Camano510 » 15 Oct 2018 08:59
Interested in these!
Darryl Cavanaugh
71 510 2dr father/son project
yenpit
Re: Rear Axles
Post by yenpit » 15 Oct 2018 15:27
DADZSUN.......interesting! You should post a FOR SALE ad once you are ready to market them!
72 510 4dr
80 720 pickup
LOTS of parts!
2002 Forester
