Random 510 parts
VelvetHammer
Random 510 parts
Post by VelvetHammer » 10 Oct 2019 16:04
1969 Datsun 510 Dashboard Cap and Frame - $200
Dash is original/beat up needs restoration
Frame has been been restored/ media blasted and painted (It's been cut for DIN style stereo).
Oil Cooler (11in x 6in x 2in) with braided lines and AN hose ends - $50
5" AutoMeter Pro-Comp Tachometer, 0-9,000 RPM, W/Peak Memory - $200
Thermostat Housing - $40
Main cap bolts
(2) Seatbelt Anchor Eyelets - $5
(2) door strikers - $10
(1) hood striker - $10
(1) Aluminum timing chain inspection plate cover - $5
(2) steering shafts - $20 for both
AutoMeter Sport Comp 2 1/2" Mechanical Fuel Pressure Gauge with Harness
Datsun 510 Front bumper brackets (2) - $20
Center Fresh Air Box (attaches to firewall and top of heater) - $50
Bosch wideband O2 Sensor (only 15,000 miles on it) - $10
(3) Motorola Radius CP200 (AAH50RDC9AA2AN) 16-Channel walkie talkies (4 active channels) - $250
(3) Batteries (probably shot)
(4) Antennas
(2) Charging Stations
(2) Westach Dual EGT gauges (Part #700-1700F, 2” round with clamps and probes) - $50
(1) V-Band Exhaust Clamp for 2.5” pipe (weld on) - $25
(1) Radiator Center Support
(1) OEM Battery Tray
(2) Hood Hinges
Lswone
Re: Random 510 parts
Post by Lswone » 10 Oct 2019 22:02
Hi, do you have the panel that holds the ignition barrel for the 69 dashboard? If so, are you willing to sell it by itself?
Regards.
VelvetHammer
Post by VelvetHammer » 14 Oct 2019 11:55
hey Lswone, sadly I don't have that part for you. Good luck on your hunt
dat_sr510
Post by dat_sr510 » 16 Oct 2019 22:25
Hey do you have pics of the race set up for the head?
Interested in the valves, the cam, lash pads and all. Pretty much the entire head.
323-404-7375
looking for a filler panel for 4dr bluebird SSS tail lights
phone: (323)404-7375
email: datmadrigal@gmail.com
PoorMtnKid
Post by PoorMtnKid » 20 Oct 2019 13:50
What condition are the strikers in for the 2dr?
