Engine Parts
D510
Engine Parts
Post by D510 » 24 Nov 2003 23:53
hi, Mark needs some stuff
Header
linkages for dual 45's (weber)
Shadbolt cam shaft
Flat top pistens
Post by Byron510 » 25 Nov 2003 18:13
Your linkage is cheap and available at Specialty Engineering or Overseas Auto. Your cam can be obtained from Shadbolt or Colt cams for about $125, flat tops, well your best bet is 280Z pistons from Lordco if your not building a killer motor... what's your plans Mark, I'm sure you could get a lot of local guidance.
D510
Post by D510 » 25 Nov 2003 23:27
where should i go if i am building a killer motor? what kind od pistons should i have?
-1988 Red Jaguar Solvereign, Cold Airintake, Exhaust, Tint, Alpine Sound System.
-1972 Black 2dr Datsun 510, slammed with Built L20B
GREG510
Post by GREG510 » 25 Nov 2003 23:32
Specialty Engineering,they do super work,super people as well
D510
Post by D510 » 25 Nov 2003 23:41
i ment where should i go for pistons... i want to build the engine.
