1972 DATSUN 510 WAGON with a KA24E FOR SALE! Car is off DMV system so will cost only $40 to register (in CALI)!!! low miles on KA24E, straight body, alloy rims, and more...
http://cgi.ebay.com/ebaymotors/ws/eBayI ... =6188&rd=1
1972 Datsun 510 with KA24E
Hey what all did you need to do your swap can you email me back at bootman4@hotmail.com
to make it super easy to do the ka swap you can get an sr20det mount kit from maddat, and the ka will drop right in with that kit. then if someday you want to swap over to an sr20 the swap would take only a few hours probibly. the only things that might need to be changed is the motor mounts. but to get the ka in a car without that kit you need to do a couple things. 1 oilpan clearance, you can either change to a rear sump pan that would have to be custom made or you can reverse the cross member. 2 you need to change the sway bar. 3 the trani mount needs to be changed to a custom one. 4 you need to cut the trani well out a bit to fit the shifter thing. 5 shorten the drive shaft. and 6 would be tochange the radiator if its a de engine. so hope that helps
