A Day at Mission Raceway
Shows, cruises & motorsport events.
Post by bertvorgon » 24 Jun 2018 17:04
We had all turned a little pale after sitting under the canopy for a few hours, avoiding the rain, as the mosquitoes had drained us of 2 quarts of blood each.
The misty rain had soaked the track down much to every ones chagrin.
There was no way Andy was going to risk the Camero out on the slick race course, he had new rotors and pads to brake in to boot and you need grip to do that. At one point it did change to a real rain and looked like the day would be a washout.
Just as we had consumed about 10 cups of coffee and were getting faint from the blood loss, it started to clear and dry up. Time to go to work.
Getting someone all kitted up in a tight Gt-1 car is actually an eye opener and quite a bit of work. After the driver is in, the HANS device is help to go around the neck, then, the helmet put on. The radio gets plugged in, the HANS straps are connected to the helmet. Safety pin pulled out of the fire system, cool suit plugged in. The GoPro camera turned on, window net is put in place. Finally un-plug booster battery. It took myself and Collin to get it all organized and quite timely. Timely being the word as the “Process” is part of a sequence of events to be ready to go instantly to the pre-grid with the engine warmed up and not get it nuclear.
Once Andy is buckled in…the monster is turned on!
It does not start in the conventional sense; it is more like a Mt. St. Helen’s has just gone off in front of you, and it happens INSTANTLY. The crackle of the exhaust is deafening, almost to that level of a Top Fuel dragster. It is a wonderful cacophony of mechanical and exhaust sound. We watch Andy for the signal that the water/oil is getting to temperature. At that signal the whole front end piece has to be attached to the car, beyond absolutely making sure that every DZUS fastener is tight and the mounting clamps are closed and latched properly. We push the car backward and then Andy is able to idle on down to pre-grid…where….a new rule in place does NOT allow engines to be run in pre-grid. So, things are timed that Andy gets there just at the point the cars are to head out.
If you have never heard a GT-1 car on the track, I could not do it justice to describe it, as it is such a visceral sight and sound. These things are missiles with an 800 HP thunder that just gets into your bones.
I had a big smile on my face!
On the last lap flag I run back to the pits to get ready for the reverse of the getting ready procedure, but, now EVERYTHING is nuclear hot. Even the bodywork (which is why it has to come off quickly so the fibreglass does not distort) where I lean into the car, you cannot touch with bare hands.
I deliberately did not wear a belt yesterday, so as to not scratch anything upon leaning into the car. Evermore, glad I did not, as it would have gotten super hot.
Lunch break had Tracey putting out a splendid food table amongst the chaos of a race day. (BOTH Specialty Cars were running, with Tracey driving her Turbo Miata also on Saturday)
The break had Andy also doing a few rotations with the rear coil over’s to raise the rear end of the car a hair.
The final race of the day had both Specialty cars down at pre-grid, which made for a great photo.
After the car cooled down some, the wheels were removed to put a fresh set of tires on. There it was noticed that one of the new brake pads had failed somehow, either a de-lamination from the bonding process, stress from flexing, or….? Brakes were bled, so I got to have a nap sitting in a nice warm bucket seat and fought off ravenous mosquitoes.
Ian was there holding up the 510 world and his car looked very, very good on the track
My day was done, that was a lot of fun, been a few years since I have done that.
As I typed this, I just checked the race results for Sundays race and Andy Placed 1st !
Harry Watson Placed 4th overall in the Specialty Mazda.
June 24/18
IMGP3591 (Large).jpeg (458.29 KiB) Viewed 2108 times
IMGP3589 (Large).jpeg (450.75 KiB) Viewed 2108 times
IMGP3588 (Large).jpeg (464.49 KiB) Viewed 2108 times
IMGP3587 (Large).jpeg (466.84 KiB) Viewed 2108 times
IMGP3578 (Large).jpeg (432.66 KiB) Viewed 2108 times
IMGP3571 (Large).jpeg (527.66 KiB) Viewed 2108 times
IMGP3567 (Large).jpeg (354.49 KiB) Viewed 2108 times
IMGP3566 (Large).jpeg (319.33 KiB) Viewed 2108 times
IMGP3565 (Large).jpeg (447.13 KiB) Viewed 2108 times
IMGP3562 (Large).jpeg (476.34 KiB) Viewed 2108 times
Re: A Day at Mission Raceway
Post by bertvorgon » 24 Jun 2018 17:06
more
IMGP3616 (Large).jpeg (413 KiB) Viewed 2107 times
IMGP3615 (Large).jpeg (525.47 KiB) Viewed 2107 times
IMGP3613 (Large).jpeg (518.56 KiB) Viewed 2107 times
IMGP3612 (Large).jpeg (439.14 KiB) Viewed 2107 times
IMGP3611 (Large).jpeg (536.49 KiB) Viewed 2107 times
IMGP3600 (Large).jpeg (385.59 KiB) Viewed 2107 times
IMGP3595 (Large).jpeg (336.77 KiB) Viewed 2107 times
IMGP3594 (Large).jpeg (366.4 KiB) Viewed 2107 times
IMGP3592 (Large).jpeg (349.98 KiB) Viewed 2107 times
Post by bertvorgon » 24 Jun 2018 17:08
more
IMGP3630 (Large).jpeg (514.81 KiB) Viewed 2107 times
IMGP3625 (Large).jpeg (358.73 KiB) Viewed 2107 times
IMGP3622 (Large).jpeg (445.75 KiB) Viewed 2107 times
IMGP3620 (Large).jpeg (644.21 KiB) Viewed 2107 times
IMGP3619 (Large).jpeg (632.45 KiB) Viewed 2107 times
IMGP3618 (Large).jpeg (618.63 KiB) Viewed 2107 times
IMGP3617 (Large).jpeg (575.28 KiB) Viewed 2107 times
IMGP3609 (Large).jpeg (349.01 KiB) Viewed 2107 times
IMGP3608 (Large).jpeg (397.33 KiB) Viewed 2107 times
IMGP3568 (Large).jpeg (481.79 KiB) Viewed 2107 times
Post by bertvorgon » 24 Jun 2018 17:16
Some random pictures. Ian's 510 for road racing, Brent's Time Attack 510, which did NOT run due to a vibration issue. The yellow wagon is Colin Jackson's and of course that gorgeous G35 is mine!
IMGP3573 (Large).jpeg (393.34 KiB) Viewed 2107 times
IMGP3569 (Large).jpeg (398.08 KiB) Viewed 2107 times
IMGP3564 (Large).jpeg (580.86 KiB) Viewed 2107 times
IMGP3563 (Large).jpeg (421.09 KiB) Viewed 2107 times
IMGP3559 (Large).jpeg (296.04 KiB) Viewed 2107 times
IMGP3556 (Large).jpeg (456.51 KiB) Viewed 2107 times
IMGP3553 (Large).jpeg (485.29 KiB) Viewed 2107 times
IMGP3552 (Large).jpeg (366.52 KiB) Viewed 2107 times
IMGP3550 (Large).jpeg (377.72 KiB) Viewed 2107 times
IMGP3549 (Large).jpeg (537.01 KiB) Viewed 2107 times
Post by bertvorgon » 24 Jun 2018 17:17
Hope you enjoyed the day at Mission!
Post by RMS » 24 Jun 2018 18:15
is there a tactical reason for having the gauges clocked ?
Post by bertvorgon » 24 Jun 2018 18:39
YES, at optimum, all things being ok the needles will be vertical.
Post by 510rob » 24 Jun 2018 19:26
I like the reinforced supports for the windshield.
GREG510
Post by GREG510 » 24 Jun 2018 23:14
Great pics Keith.... Looks like it would of been fun
Post by funwithmonkeys » 27 Jun 2018 20:45
That looks like it was fun. Andy gave me a good look at his car one day when he was working on my car. That is a pretty amazing piece of kit.
