Knox mountain
Knox mountain
Where is it located and can only race cars enter? is it still on the may long weekend.
- Nickel-n-Dimer
- ///FiveOneOh
You need to have a few things to pass tech, depending on what class you are in.... some can go with a roll bar, some classes need a full cage, inside kill switch, outside kill switch, basically a safe car that passes tech, good suspension, no structural rust, helmet is a must, as is fire suit in some classes.....
but the Tigers usually don't, but I thought the same as you...they even failed someone last year in a Corvair becuse of his cage.510rob wrote:I seem to remember that FIA/ASN or whoever it was forced them to mandate a full-cage minimum which prevented a lot of people from running quasi-streetable cars (like Keith's car)
I should be showing up Sunday ( I hope ), my sister's getting married on the Sunday and I'm not sure of the plans for the whole weekend.
richard norrish
Some cars were granfathered on the full cage thing. Others, like mine and Cam's HAVE to have full cages ( good thing to have at Knox) Has anyone heard if Knox is a go this year? I heard a rumble that JIM KELLERMAN is not going to organize this year. Has anyone else stepped up to the plate?
Jim K got back to Malcolm last week, and the Knox event is a go - Jim just won't be at the helm, although he said he was going to help out. So let's go, I'll be there to help Kieth if you are planning on attending, Sean has the time booked off work to run the 1200, and Malc's building a motor......
You need a cage depending on what swap you have... I know that swaps with forced induction, such as keiths car must have a cage. and if they failed a coviar because of its cage, it must have been one crappy cage!!! they pass cages that look like they were welded by 2 year olds... And like keith said, nice to have a cage for knox even if it wasnt required, if you have ever gone up knox at over 100mph, you would be wanting a cage, its a tight, sometimes scarry course
