problems with private messages
Problems, Comments, Questions regarding the website
Post by RMS » 26 Nov 2015 14:54
I keep seeing new private message 1, then I click on pm see the subject, click on the message and there is no body and I get an error message.so I go in to my user control panel see a bunch of "Defined rules" or that pm's are turned off ? I have never defined a rule blocked or turned off messaging.......what is happening?
if a user deletes a sent message does it delete it from my inbox?
do other users rules get defined in my list ?
:? what am I doing or not doing ? :?
Re: problems with private messages
Post by Byron510 » 26 Nov 2015 14:57
Your inbox is too full - clear it out, hit "Release on hold messages" button at the top and you'll be good to go
:D
Post by RMS » 26 Nov 2015 15:16
my folders are @ 70% I had inbox set to delete oldest message. no such Release on hold messages button that I can see.
if my folders were full would it explain why a rule was set ex: mark all mcshagger messages as read move to manage?
I just sent a pm to robert about his D slot add. saw it in the out box. refreshed page message no longer in my out box and no copy in my sent folder ?
twistin
Post by twistin » 26 Nov 2015 16:40
Sent you a pm yesterday RMS ,guess you never got it.
Grant 778 *** ****
My other car is an unfinished project.
Post by RMS » 26 Nov 2015 17:11
K
Post by bertvorgon » 27 Nov 2015 05:16
Did you get mine? Come over and see my Boler at work.
Sent on Friday the 13th...whoa...maybe that was the reason....
Post by RMS » 27 Nov 2015 08:09
I didn't post that K
Post by RMS » 27 Nov 2015 09:06
I did get yours Bert....I guess only the spooky one's get through....boler still there?
Post by bertvorgon » 27 Nov 2015 12:35
Boler still here, will be for a good chunk of the winter, have to repair my furnace and do a few other tiddly things.
I have tree trimmers coming to my home, so I needed to move it out of the blast zone anyhow, glad I have some room
next to the 510.
Come around anytime, 6;30 to 2;30
Post by RMS » 19 Jan 2016 19:19
so today I get a message, guy wants a head. reply with my usual "I have a few send me your # and a time..." come back later to read the response... reread it a few times and wonder why he never sent a # scroll down the page and my response had chained to " No sorry " . the time did not correlate with my original post.
Post by RMS » 30 Jun 2016 10:20
ok starting to get really pissed ! every week I change my password and still I find blocked messages with new rules defined.
****mod edit - sorry Robyn :-) Hope you understand - byron****
moderators are you able to see where logins are taking place ? is there any suggestions on how to stop these malicious attacks.
Post by Byron510 » 30 Jun 2016 10:28
Robin - call me on my cell.
Post by 510rob » 30 Jun 2016 17:08
Hi Robyn,
All of the logins to your RMS account have originated from dynamically assigned IP addresses that fall within one of three owned IP ranges:
  • 24.114.-.- = Rogers Cable Communication
  • 72.136.-.- <---> 72.143.-.- = Rogers Cable Communications
  • 74.198.-.- = Rogers Wireless
No logins appear to have been made to your RMS account from any IP range owned by any other ISP.
If you give me your e-mail address, I'll send you a bunch of screen captures (9 of them) that show the entire login history for your RMS account.
Post by RMS » 30 Jun 2016 17:40
I noticed some of the times of login are not congruent with my scheduled ie 6:55am utc......
I have never logged into the realm on a different computer. I run a rocket hub and have no other internet connection.
im rogers wireless not cable unless that can change with the rocket hub setup?
Post by 510rob » 01 Jul 2016 12:35
I think it is safe to assume that your Rocket Hub - operated using Rogers Communications as the ISP - gets a dynamically-assigned IP address from any of the Rogers-owned IP ranges, whether those ranges are listed as a Rogers land-based concept or a Rogers Wireless-based concept. After all, that is exactly what makes dynamic IP the beautiful thing that it is.
RMS wrote:I noticed some of the times of login are not congruent with my scheduled ie 6:55am utc......
Does anyone else have access to that computer?
