Page 1 of 1
hooking up tach on SR20det?
Posted: 19 Nov 2008 12:11
by johnbureezu
Finally getting around to installing an autometer tach and I have the module to make make it work with the sr individual coils. My question is; Do you have to tap into each coil's power wire like it says in the autometer instructions or is can I just tap into the tach signal wire(single wire)? I 'd really hate to splice into each coil wire.
thanks
Re: hooking up tach on SR20det?
Posted: 19 Nov 2008 12:56
by icehouse
I hooked my aftermarket tach to the output on the ECU, worked fine, I forget what brand tach I had though.
Posted: 19 Nov 2008 13:34
by sdterrible1
id like to know this also?
Posted: 19 Nov 2008 14:20
by johnbureezu
icehouse wrote:I hooked my aftermarket tach to the output on the ECU, worked fine, I forget what brand tach I had though.
Really? hrmm. I'm gonna have to check that out. Maybe the autometer tachs are different.
This is what I have.
http://autometer.com/cat_accessoriesdetail.aspx?vid=99
Posted: 19 Nov 2008 16:01
by hang_510
that thing got a hemi?
i think the directions are for a hemi only???
would be "Connecting to an Individual Coil Per Plug Ignition System" - should be the hook up you need.
or "Connecting to a Coil Pack"
Posted: 19 Nov 2008 16:48
by johnbureezu
Yo hang. i have the instructions and it says to splice into each coil power. Thats what I'm trying to avoid doing. There has to be a simpler way to do it. Maybe I'll try the Ice technique when I get home tonight..
Posted: 19 Nov 2008 19:02
by icehouse
Yeah you don't want to splice into each coil, that would back feed the power and cause a big mess. Unless you wire in some diodes, that work. I would try it to the tach out put for fun :D Hey the worst that could happen is it wouldn't work.
Posted: 19 Nov 2008 23:06
by johnbureezu
icehouse wrote: I would try it to the tach out put for fun :D Hey the worst that could happen is it wouldn't work.
Got that right... I got lazy so I'll prolly try it tomorrow or priday.
Posted: 20 Nov 2008 06:25
by RWD_NissanMan
I just used the 180SX/Silvia tach and stuck it in the dash to replace the old 510 one. Wired it directly to the tach out line on the ECU. This seemed to me to be easier - mind you I had a front clip to work with which maybe you don't.
Posted: 20 Nov 2008 11:49
by S15DET
I wired my aftermarket tach (Classic Instruments) to the tach output wire from the ECU and it worked fine.
Posted: 23 Nov 2008 02:21
by johnbureezu
Awww shiet! I just hooked the tach up and all I had to do was hook it up to the tach output(yellow w/ red stripe) and boom good to go. Thats what I get for getting my info on zilvia.net before asking over here. Now I have a $75 piece of shit module laying around. :oops:
Posted: 24 Nov 2008 10:17
by hang_510
johnbureezu wrote: Now I have a $75 piece of shit module laying around. :oops:
dont ya love electronics??? post it for sale on zilvia.net :twisted:
the return policy at the electronic shop i used to work at..."if the part you bought and installed wasnt the problem, you now have a spare- NO returns."
8) that it was easy.
Posted: 03 Aug 2011 19:08
by Braden620
what type of module do you have? is it the adapter that allows the use of the factory tach?
Posted: 04 Aug 2011 00:11
by johnbureezu
I think it was a mustang type module. not sure if it'll work for a stock tach though.
