sequential taillight box hook up, HELP, PLEASE.
- tycot1
could and would someone help me out with the sequential box hook up. i have the two box set and i am unsure in what order these things are supposed to be set up.
Re: sequential taillight box hook up, HELP, PLEASE.
I think it's pretty fool proof, the harness has a connector under the speaker tray, you unplug that and the boxes hook into there, go thru the boxes then back to the tail lights...I am not sure in anything other than a coupe.....
- tycot1
so the harness feed from the front goes into the 6 plug male connector at the relay, then out of the female connector at the relay to the stock harness. the relay box has a third connector that has a three prong female connector on it.the flasher box has only one connector which is six metal prongs sticking out. does the three prong female connector on the relay box somehow go to the six metal prongs on the flasher box?
Rich, remember this is/was a sedan...
richard norrish
oh yea....now I know your car...you made the coupe....yea, you are going to have to splice into the wiring, I can try to find you a harness.....but not sure If I can......maybe the colors are the same in your harness as they are in the plugs that go into the boxes, hard to tell without seeing them for myself. sorry I can't help more.
