Rear Brake lines
paul97
Rear Brake lines
Post by paul97 » 03 May 2009 17:46
I have a 69 510 4 door and I was wondering if anyone knew where I could get the rear brake lines that go from the rear wheel cylinders up the rear arm to the flex hose. I would like the correct length and pre bent if possible.
gnar510
Re: Rear Brake lines
Post by gnar510 » 04 May 2009 03:52
Pm nasaracing510. I'm quite sure he has some he would sell you.
paul97
Post by paul97 » 05 May 2009 15:41
I went to my local Nissan dealer this morning and they said they have been obsolete since 1984.
hang_510
Post by hang_510 » 05 May 2009 15:43
i got a set off a junker.
you can have the old lines w/stripped nuts, to use as a template for new...
Post by okayfine » 05 May 2009 16:06
hang_510 wrote:i got a set off a junker.
Pretty much. You could also get braided stainless lines in the length necessary to replace the short steel lines, or go from the rear brakes to the T fitting and eliminate the rubber as well.
