I need help
dat5102dr
I need help
Post by dat5102dr » 04 Sep 2011 15:38
when i take out my datsun and i give it gas it feels like its not wanting to go
it runs but i have to keep it really slow but it still changes gear
my father says its not getting enough power
at first he thought it was the clutch
I am not sure
does anyone have a clue?
Re: I need help
Post by defdes » 04 Sep 2011 16:31
It sounds like it could be a timing or fuel delivery issue, do you feel/hear/smell the clutch slipping. We'll need a bit more history and detail on the car to successfully help you.
Re: I need help
Post by James » 04 Sep 2011 16:37
OK - list of questions - answer them all and we can probably help you.
1. have you been driving car regularly - new gas etc.?
2. Is car manual or automatic?
3. Stock carb/engine?
4. Points/electronic distibutor?
5. What if anything have you messed with/replaced recently?
I agree with defdes - but some more info would help us point you in the right direction.
510-Trevor
Re: I need help
Post by 510-Trevor » 04 Sep 2011 16:38
If you post your location in your profile, someone local may offer to come over and help.
1972 Yellow 4dr - 1972 Red 2dr
Re: I need help
Post by datzenmike » 04 Sep 2011 18:09
If it takes off alright and drives fine at low speed but but quickly starts to jerk and stutter like you are turning the ignition off and on when you accelerate, the fuel filter may be full of dirt. They are cheap so just get one and replace it if you do not know when it was replaced last.
dat5102dr
Re: I need help
Post by dat5102dr » 06 Sep 2011 15:33
I think it was the carb
my dad took out the big filter and push something in and he said that was the problem
Ill try to take it out for a little cruise today to make sure
Has anyone had that problem before?
RonM
Re: I need help
Post by RonM » 06 Sep 2011 15:46
Not sure what you father "pushed in" to fix the filter, but yes a clogged filter would cause those symptom, and it's pretty common. Get back to us with a follow up on how it running.
Good luck/
Re: I need help
Post by two_68_510s » 06 Sep 2011 16:00
Must have been the choke, it may have been sticky.
Re: I need help
Post by James » 06 Sep 2011 16:21
dat5102dr wrote:I think it was the carb
A few pics - would really clear things up. Hope you got it fixed.
dat5102dr
Re: I need help
Post by dat5102dr » 08 Sep 2011 20:36
That was the problem
The Carb had something sticking out (under the filter)
Does anyone know what causes that?
Re: I need help
Post by two_68_510s » 08 Sep 2011 20:40
Can you be a little more specific?
What was the problem?
Sometimes the threads are not in order, and you need to reference your responses
What was sticking out, and what happened to it?
dat5102dr
Re: I need help
Post by dat5102dr » 11 Sep 2011 12:36
I was two cylinder looking tubes that are there in the card
i pushed them in and it clicked
Before when i drove the car
i gave it gas it would sort of bounce
my dad said it was not getting enough strength
It ran and it changed gears but it would not go fast
510-Trevor
Re: I need help
Post by 510-Trevor » 11 Sep 2011 13:05
IMO, at this point, your inability to communicate using automotive terminology tells me that you are in over your head. If you really want some help and are not just some troll seeing how far he can take this, post some pics of the parts you are trying to describe. Answer the questions we are asking and post your location and ask if there is somebody nearby that can help you. Next, go buy one of the recomended repair manuals.
Re: I need help
Post by James » 11 Sep 2011 13:13
I agree - not getting much back at this point that is useable, much less legible. Picture is worth 1,000 words, probably 10,000 in this case.
banzai510(hainz)
Re: I need help
Post by banzai510(hainz) » 11 Sep 2011 20:46
Though my writting was bad.
What I can make out hes talking SUs
Best to sell the car or learn L motors really fast. There simple motors
olddatsuns.com
